Question about Samsung Office Equipment & Supplies
My samsung laser jet printer turns on then goes off then it keeps just randomly turning on try to print then goes off again
Posted by louise daniel on
5 Related Answers
Soulvisitor
Soulvisitor
  • 1113 Answers
SOURCE: Printer HP Laser Jet 7400
A critical firmware error has occurred that caused the processor on the formatter to abort the operation.
This type of error can be caused by invalid print commands, corrupt data, or invalid operations.
In some instances, electrical noise in the cable can corrupt data during transmission to the printer.
Other causes include poor quality parallel cables, poor connections, or specific software programs.
99 % of time it is a corrupt file or poor connection, I have also known it to be the firmware, dimm or formatter board on rare occasions.
Recommend check hp web for any firmware updates, check connections and that driver is installed impecablly and use known good files to test.
Posted on Dec 27, 2007
Anonymous
SOURCE: tvalue 4 for windows will not print with a new printer
This is a work around as I have the same problem. If I change the default printer to something other then the HP printer, then select Page Setup, I can then select the HP without the program erroring out. You can even set the HP back to default and TValue will continue to work fine until you restart the computer.
Posted on Mar 12, 2009
Anonymous
SOURCE: not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Posted on Dec 02, 2009
wheatlandsvc
Edwin Martens
  • 1110 Answers
SOURCE: HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Posted on Jan 05, 2010
Testimonial: "It worked. Thanks. I' just FIXYA again"
col
  • 8 Answers
SOURCE: Samsung Jet (S8000) software issues
flash with this: file:///C:/Users/stacey%20scannell/Desktop/cols%20stuff/cols%20phone%20apps/boot%20info%20for%20samsung%20flashing/S8000%20FIRMWARE/XEII2
Posted on Jan 15, 2011
Laser printers / Ink Jet printers the difference
Depending upon what you are printing and how you want it to look. Also cost is a factor. We sell new and used printers at our storefront. If you are printing items you do not want to smear if they get wet - Go laser. If you are printing photos on photo paper - Go ink. Some people fail to tell you when selling a color laser jet printer that when you are are printing just black, you are also using each of the colors a little. Toner is the lubricant that keeps the drums from squeaking on the blade as the drum inside the cartridge turns. The buildup of excess toner in the waste container may cause the cartridge to fail though you have only used a little in the cartridge. Laser and Led printing black only is the most efficient way to print. We don't usually recommend color laser printers unless that is all you are going to print are full color documents. Color can be expensive. Inkjet is more expensive to only print black with. While if printing color, it is less expensive than laser. If you need more information please ask!
Jun 03, 2014 | Computers & Internet
I am getting Error 49..turn off and turn on error again and again from HP 2605 Color laser jet printer. Plz help.
It's a firmware error.
Do ALL your print jobs give this error. If it is just one job that causes the error, something is corrupted with the software.
If every print job causes the error, it's the printer. Try printing after removing DIMMs from the printer. If you can try plugging the printer into another port on the computer or router.
When all else fails, go to www.hp.com/#support and download the latest firmware and install it.
By all means READ the directions first.
Jan 31, 2011 | HP LaserJet 2605dn Printer
When I turn my printer on, the light goes green, but it keeps doing the "boot up" sound without stopping. If I let it go long enough I can smell the motor getting warm. It doesn't stop and will...
Try taking out the Drum and toner cartridges, ensure there are no blockages in the paper channels. Re-install and reconnect to mains.
Please rate this answer.
Cheers
Bob
Jan 09, 2011 | Samsung ML 2010 Laser Printer
Samsung clp300 color laser printer not printing
The cartridge dried out and the moisture/liquid sensor will no longer detect new fillings though the layer. A good refill needs to be done before the ink is out. These are tedious little critters. Try the nozzle cleaning procedure several times(through your printer's software. Take out the cartridge and set the jets on a cotton ball soaked liberally with cleaning fluid. Run the nozzle cleaning procedure again.
Jul 05, 2009 | Office Equipment & Supplies
L6 error keeps popping up
That is a laser error. The motor that drives the mirrors is most likely oing bad, The laser unit will have to be replaced.
Jan 30, 2009 | Xerox WorkCentre XD105F Laser Printer
HP clj3505 print spooler
Set to PRINT DIRECTLY TO PRINTER in control panel.
Dec 08, 2008 | Xerox Phaser 6250DP Laser Printer
Xerox Phaser 8400N Printing Stripes
When you go into the eliminate light stripes there is also a mode called Jet Substitution. You can sometimes bypass the bad jets.
If that does not work then the print head will most likely need to be replaced.
You can replace the printer for less than the cost of a print head normally..
Jul 08, 2008 | Xerox Phaser 8400 Laser Printer
USB not online?
u first uninstall driver,after installing restart the computer after that connect the printer again,n see does it informs that new hardware found n shows the printer name on the screen,if yes then insatll the driver again
Jan 14, 2008 | Samsung ML 2010 Laser Printer
24 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
