Question about Garden
Setting up the fuel lines on a yard machine 3100m weed trimmer
Posted by Noel Ramirez on
5 Related Answers
Anonymous
  • 297 Answers
SOURCE: I REPLACE THE FUEL LINES,NOW IT ACTS LIKE IT WANT TO START,BUT D'
http://outdoordistributors.com/pdf/Ryobi/RYOBI-700r-serials-304051232-thru-.pdf
Have a look at this drawing.
Posted on Apr 18, 2009
#1 Taper
Jim Parker
  • 1041 Answers
SOURCE: Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
Posted on May 26, 2009
#1 Taper
Jim Parker
  • 1041 Answers
SOURCE: my homelite weed eater sx-135 the fuel filter broke of the tube
The longest, and sometimes smaller in diameter, fuel line goes from the carb. to the bottom of the tank. It should rest comfortably on the bottom of the tank. The other line should go from the primer bulb to just inside the gas tank, (about an inch).
HINT: Cut the fuel lines at an angle before inserting them into the gas tank. This will allow you to get them in much easier.
If you need further assistance, just let me know.
Jim
Posted on Jun 08, 2009
Anonymous
SOURCE: repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Posted on Sep 05, 2009
rycgl
Roy Cagle
  • 1545 Answers
SOURCE: replacing fuel lines on ryobi weed eater,need
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Posted on Jul 10, 2010
HOW TO REPLACE DUAL LINE ON GRASS TRIMMER
search google for "YARD MACHINE 31CC GAS TRIMMER Manual". the manual is there I have seen it. also check youtube.com
Hope this helps...
May 01, 2016 | Yard Machines Garden
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
Yard machines trimmer. 4 cycles
Victor you need to invest in some copper grease. This will stop it getting to hot and jamming when it expands with the heat.
Apr 26, 2014 | Yard Machines Garden
Weed eater wont start
If you haven't changed fuel filter in awhile, do that as well.
look here...
Aug 01, 2010 | Craftsman 25cc Gas Line Trimmer
Where can i download an instruction manual for my weed trimmer?
Try this link and see if you can find the manual that you are looking for. I don't know what model your trimmer is but take a look here. Sure hope
this helps and best wishes. .
http://www.manualsonline.com/search.html?q=yard+machine+lawn+trimmer&submit.x=16&submit.y=12
Aug 26, 2009 | Yard Machines Garden
Repairing fuel line on craftsman 32cc weed trimmer.
Aug 24, 2009 | Craftsman 25cc Gas Line Trimmer
Weed eater TE475 - fuel ratio
FUELING ENGINE
WARNING:
Remove fuel cap slowly
when refueling.
HELPFUL TIP
To obtain the correct oilmix
ratio, pour 3.2 ounces of
2--cycle synthetic oil into
one gallon of fresh gas.
This engine is certified to operate on unleaded
gasoline. Before operation, gasoline must be
mixed with a good quality synthetic 2-cycle
air-cooled engine oil designed to be mixed at a
ratio of 40:1. Poulan/Weed Eater brand
synthetic oil is recommended.Mix gasoline and
oil at a ratio of 40:1. A 40:1 ratio is obtained by
mixing 3.2 ounces (95ml) of oil with 1 gallon (4
liters) of unleaded gasoline. DO NOT USE
automotive oil or marine oil.
Jul 05, 2009 | Yard Machines Garden
I inherited a Weed Eater 1500 gas yard timmer. In
well there should be the prime bubble well screw it if you can call me i can help. 706-354-3867 my name is callie
Apr 28, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
