Question about Swiss Grill Grilling
Ignitor not working on Swiss grill outdoor grill
Posted by Ken Norbe on
Phillip Cain
    Habit-Forming:
    New Friend:
  • 10 Answers
Did the igniter continuously sparks when the button was pressed?
If it did, the igniter usually has a battery.
Try twisting the igniter button counter clockwise it gain access to a battery compartment
I fixed a CharBroiler grill’s igniter this past weekend by replacing its AA battery.
Posted on Jun 04, 2019
5 Related Answers
Anonymous
SOURCE: gas grill ignitors
I recently moved. When the grill arrived to the new home I had to purchase a new propane tank to replace the old one. The grill will not light. For some reason it isn't getting any gas. Any suggestions on what the problem might be?
I tried the obvious... tightening the connections, trying to light it manually etc.
Thanks,
K
Posted on Jul 13, 2008
Anonymous
  • 1185 Answers
SOURCE: Weber Genesis outdoor grill. The ignitor clicks
If you hold down the igniter can you smell the gas coming out of the burners.
Have you disconnected the pipe from the barbie to see if the bottle regulator is actually letting gas through.
Turning the gas on in free air with no one smoking or naked fllames near the pipe is ok
You just crack open the valve a turn or two and you should hear and smell it.
If there is gas coming out og the pipe and not out of the burners then the gas control valve in the barbie is at fault and needs replacing
Posted on Jun 27, 2009
Anonymous
  • 22 Answers
SOURCE: Ignitor Quit Working
Remove the switch and the wire from it as you will have this little switch and a wire push the switch and watch the end of the wire there should be a spark it not you can dog wife check it if you want too. stick the end of the wire to the dog re the wife and push botton if they scream and jump a few feet the switch is good . jus kidding . if it is good just locate the end of the wire so that it is in a more effective position to light the gas,
Posted on Aug 09, 2009
Anonymous
  • 9 Answers
SOURCE: ignitor on performer grill stop working. Can
Call Weber at 800-466-1071 and order the ignitor kit: http://www.weber.com/publicSchematic/view.aspx?model=841004&Sequence=26&Suffix=
Posted on Aug 22, 2009
Anonymous
  • 388 Answers
SOURCE: Need cookbook for George Foreman Indoor/Outdoor Grill
No problem! Hopefully she will read some of the recipes on the site and use them, then change her mind about the cookbook...you never know!
Posted on Jan 28, 2010
How do I replace ignitor switch in thermos gas grill, if this is what is what I saw?
If that white is ceramic, I think it is the actual ignitor, not the switch.
Apr 29, 2017 | Thermos Stainless Steel Gas Grill
How to replace electric ignitor for outdoor grill?
it may be that the electricity or the spark is connection to different point of the grill, the electricity will spark to the closest point of conductivity.
if you check and each ignitor is sparking , strongly ( so no problem with spark modual), then there may be points in the wireing whichis exposed or more likely where the wireing and the ignitore connects,
you can tape it with electrical tape, then it should see the spark to the burner. if it is sparking, and not to the burner, just means it is sparking to a different point, where the jump is shortest.
Apr 18, 2013 | Cooktops
Ignitor doesn't work on DCS grill
Just use a 9 volt batterie
Jan 20, 2018 | DCS Grilling
Broilmaster P3 series (purchased circa 2001). Just replaced burner, ignitor and converted from Propane to Natural. Fired the thing up and it appears to flame (difficult to see), but it just won't warm...
If you didn't change the burner orifices to Natural Gas orifices, that's the problem. Even after those are changed (assuming you didn't) the grill will take a bit longer to preheat. As Propane burns cleaner and hotter than Natural Gas, in an outdoor environment.
Hope this helped answer and solve the problem for you.
May 02, 2011 | Broilmaster P4F (NG) Grill
Jan 28, 2010 | George Foreman 532 Sq. In. Outdoor BBQ...
Ignitor on performer grill stop working. Can
Aug 22, 2009 | Weber Performer Grill
Aug 08, 2009 | Grilling
Jun 27, 2009 | Weber Genesis Silver B Grill
Indoor Grilling vs. Outdoor Grilling.
Basically, if you can grill it outdoor - you can grill it indoors. Notice that indoor grills can't drain liquids as well as outdoor grills, so this should be kept in mind. Bon apetite!
Aug 01, 2007 | Toastmaster TG21W Indoor Grill
Grilling Logo
240 people viewed this question
Top Swiss Grill Grilling Experts
Paul Carew
Marvin
Marvin
Tom Chichester
Are you a Swiss Grill Grilling Expert? Answer questions, earn points and help others
