Question about Medical
Our Mac 1200 ekg machine does not print out the measurement results. How do we fix this?
Posted by Dennesa on
Andrew Taylor
    Top Expert:
  • 33,305 Answers
5 Related Answers
Anonymous
  • 71 Answers
SOURCE: Marquette MAC 6 EKG machine prints extra pages
You are using the worng paper. Cross refrence the paper you are using with the correct number.
Posted on Jun 03, 2009
Anonymous
  • 71 Answers
SOURCE: Paper starts then stops before printing results
most likely wrong paper or a bad optical sensor. There are actually 2 or 3 different versions of the mac 1200 all of which might need different paper. if you tell me the serial umber of your unit and the part number for the paper you are using I can tell you what is the correct paper.
If you have further questions you can contact me at [email protected] or through our website www.overstockme.com
Posted on Jul 18, 2010
Gene Pitts
  • 159 Answers
SOURCE: When try to record ekg tracing on my MAC 15 EKG
Hello n_baluyut, visually check the RS232 plug pins, both male
Posted on Oct 14, 2010
AJIN G
Electro Med Services
  • 6694 Answers
SOURCE: Our MAC 1200 ekg machine
hi,
1.Press the setup Button
2.Select operating mode and press enter.
3. Repatedly perss the down arrow until it reaches to the "START AT QUEUE MARK" and perss enter. Then select NO and press enter ( if it is selected Yes then before each recording the recorder advance the paper to the beginning of the next page)
4. Press the Start button to exit the setup.
From the next EKG it will print from the first page.
ok
Posted on Aug 11, 2011
mike
SOURCE: I have EKG machine GE
Rotate the paper so the sensor can find thepaper.
Posted on Nov 15, 2011
How to load paper
How to load paper - Fixya
www.fixya.com > Forum > EKG/ECG Machines
39 mins ago - How to load paper - EKG/ECG Machines question. ... Machines. Open Question ... Aug 30, 2012 ' Schiller Cardiovit At 2 Light Ecg Machine.
Loading paper into the MAC 1200 ecg machine - Fixya
www.fixya.com/.../t4590309-loading_paper_into_mac_1200_ecg_mach...
Apr 19, 2010 - loading paper into the MAC 1200 ecg machine how to load the paperinto the machine? ... Ge Medical Systems Ge Marquette Mac 1200 question.
Contec ECG Monitor & pulse oximeter Ekg printed sheet ...
www.hcuck.com/search/p1207318-contec_ecg.../ekg_printed_sheet
Question about Ge Medical Systems EKG/ECG Machines ... Open the . ... ...ekg-manual The paper is is backwards, there are 4 ways to load paper BUT only 1 ...
Electrocardiograph (EKG / ECG) Questions and Answers
Dec 21, 2015 | Medical
EKG machine not printing properly
hi,
If its mac 1200 then try to check the battery and replace the same. here i have added the part number of the battery. Hi,
Here is its part number 303 44270, 18V 1.4Ah nickel cadmium Battery ,
Jun 07, 2013 | Philips AED FR2+ with Extras
Can a Schiller AT2 ECG paper size ( 8.5 * 11) inches be used on a GE MAC 1200 EKG machine?
hi,
Both machines uses the same dimension paper ( 8.5 * 11 Z fold paper ). You can use the paper in GE MAC 1200 EKG machine.
ok
Sep 27, 2011 | Ge Medical Systems Ge Marquette Mac 1200...
Our MAC 1200 ekg machine prints out 1 empty sheet prior to printing the actual ekg. Is there a way to eliminate that first page? It wastes a ton of paper. thanks, Dan
hi,
ok
Aug 09, 2011 | Ge Medical Systems Ge Marquette Mac 1200...
I have EKG machine GE MAC 1200. I change the paper now it is not printing with new paper. What should I do?
Our EKG machines at work have specific paper that will only work with them, are you using the same type as before? Also, it is possible to put the paper in upside down and it will not print on that side. Have you tried to turn the paper around? Good luck
Apr 26, 2011 | GE Medical
I think that the ink on my GE Mac 1200 EKG has run out. How do I replace it? Where can I get ink?
hi,
it doesn't uses any ink. printout is given by a thermal printer on wax or chemical paper. if print out is not coming ,then there may be possibility of the thermal printer head become damaged.
also check the battery .
ok
Dec 07, 2010 | Ge Medical Systems Ge Marquette Mac 1200...
May 27, 2010 | Ge Medical Systems Ge Healthcare Mac 1200...
GE MAC1000ekg not printing clearly . My EKG machine is recording the EKG well but when I print it comes out very faded.
The heat on the print head can fade over time giving you a poor print. also the feed roller can wear and give poor pressure to the print head. thw way to diagnose it is to put a peice of electrical tape on the print roller and print an ekg. if it prints well in the area where the tape was, it is the print roller. if there is no change it is the print head.
[email protected] www.overstockme.com. Jeff Watson
Nov 17, 2009 | Ge Medical Systems Ge Marquette Mac 1200...
Marquette MAC 6 EKG machine prints extra pages before and after report. Any suggestions?
Mar 19, 2009 | Ge Medical Systems Ge Marquette Mac 1200...
Medical Logo
220 people viewed this question
Top Medical Experts
Andrew Taylor
Andrew Taylor
Rhonda Webster
Rhonda Webster
Are you a Medical Expert? Answer questions, earn points and help others
