My Harmon Kardon GoPlay wont charge. When i plug it in it wont charge
Posted by Jared Heydenrych on
Franco Dosil
    Top Expert:
  • Audio Player... Master
  • 10,535 Answers
Hello Jared, try another charger of similar characteristics, is a charger of 19 volts 3 amps, if you do not charge, or you have a problem in the battery or charger connector
I suggest you consult a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Jared, prueba con otro cargador de similares carcteristicas, es un cargador de 19 volts 3 amperes, si no te carga, o tienes un problema en la bateria o el conector del cargador
te sugiero consulters un servicio tecnico especializado
Espero puedas resolver el problema
Saludos Franco Dosil
http://www.fixya.com/answer/answerpageslideview.aspx?ctg=mine&fml=0&brd=0&thid=27355827#
Posted on Jun 03, 2019
5 Related Answers
Anonymous
  • 51 Answers
SOURCE: Harmon/kardon computer speakers bought on ebay missing power adaptor
Get the speakers with you walk a distance for your Nearest electrical shop as quickly as possible and your roblems will be solved...
Posted on Jan 04, 2008
Open SKy
Carlos L. Burgos
  • 620 Answers
SOURCE: Harmon Kardon Sound Sticks
Hello there
First things First:
1) check cables, and the input cable to your PC.
2) Check for right voltage, may be somethings is chargind a lot**
3) Power regulator on the Speakers is damage.
4) RMS your Spks, for replace. or warranty.
5) try in another computer. ( if apply)
Posted on Jan 26, 2008
Anonymous
SOURCE: Harmon Kardon unlock error
I have the same problem. All of a sudden no sound through my TV connection (but through the DVD connection the sound was still working). I changed the connection from video 1 to video 2 and got the sound back. It is not a real solution, but a practical one :-)
Posted on Feb 01, 2009
Anonymous
SOURCE: How do I disassemble + clean Harmon Kardon SoundStick subwoofer?
Check for a Fuse. Mine is an older model and has a Fuse right next to the power cord. It probably has a slot for a flathead screwdriver.
Posted on Jun 09, 2009
ironcrossaud
Iron Cross Audio
  • 281 Answers
SOURCE: changeing to newer radio in 2000 harley ultra
06 - 10 HK radios are a direct plug in to the 23 pin main pwr / spkr connector. It will work as long as you have no external accessories
Posted on Sep 23, 2009
Harmon/Kardon AVR 146 wont stay on when hit power
Probably was damage buy a power surge, Internal damage to (Reciever)
Nov 03, 2012 | Harmon Kardon Harman Kardon Avr 146 5.1...
Harmon Kardon Go+Play speakers wont work on Del laptop with Windows 7.
click start control panel hardware and sound manage audio devices playback
you should see your speakers right click select enable or you might have to configure them this option will be at the bottom of of the playback list also right click on the speaker select properties
you should see a few tabs general levels enhancement and advanced you might find you need to select a different option possibly stereo or dvd or studio quality windows7
hope this helps
Feb 16, 2012 | Harman Kardon Audio Players & Recorders
Harmon/Kardon SoundSticks 2, Power adapter?
If you go to the Harmon/Kardon website, you can find where to buy replacement parts.
http://www.harmankardon.com/
Select product support on the front page, then go to parts.
Then select your product as Harmaron/Kardon SoundsticksII and select your country.
Hope this helps,
Nathan.
Mar 31, 2009 | Harman Kardon Harmon Kardon SoundStick II...
Changeing to newer radio in 2000 harley ultra
no, besides the harmon kardon using molex connectors. I wouldn't attempt.
Jan 29, 2009 | Harman Kardon Sony CMTNEZ3 AM/FM Radio...
Harmon kardon 745 displays "unlock" no sound for tv or movies
I also had this UNLOCK message on my Harman Cardon AVR 130.
The reason for this error was - in a hurry I've plugged the optical input into optical OUT! Double check that your connections in the back are correct and hopefully it fixes your problem.
Cheers,
Sergey
Jan 11, 2009 | Harman Kardon AVR 130 Receiver
I need a cigarette lighter plug for my harmon kardon GPS, and I cannot locate the 800 number for harmon kardon.
My cigarette lighter does not work, do i need it to use the Garmin Nuvi 255w?
Aug 26, 2008 | GPS
Harmon/ Kardon ST-8
Harmon kardon.com and check product support or check the website where you got them from, If they still cary them you may be able to find a manual as a pdf or something. Good luck. Bonne chance!
Feb 26, 2008 | Harman Kardon Harmon Kardon SoundStick II...
26 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
