Question about Dirt Devil Vacuums
My dirt devil steam mop PD20000 is not producing steam
Posted by Marjorie Earle on
5 Related Answers
satch498
satch franklin
SOURCE: shark steam mop
I had the same prob and found this site off google looking for the solution.
I went back to my shark and took out all the screws, some don't feel like they were coming out but it came apart. Take a pair of pliers and release the spring clip holding the hose to the heat nozzle. Then pull off the hose. Then take a paper clip, unkink it so it's sort of straight with a curve to go into the hole . Shove it in and out to clean out the hole. I got my fingers blasted with residual steam so you should let it cool first. But I think the steam bursting out helped clean out the hole. Don't throw it away till after you try that..It worked great after that. All the best, Satch
Posted on Jun 30, 2009
beechgirl223
SOURCE: need instruction on dirt devil mop vac
I found very basic direction on eHow
Posted on Mar 20, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: No steam coming out of my shark mop.
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Sep 24, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: my mop would produce steam. It gets hot but when
heatman101
xxxx
Jsmarshall34
SOURCE: Dirt Devil Deluxe Easy Steam Mop won't steam
Hi Slatts51 I am having the same problem it worked wonders the first time I used it, now its doing the same thing as yours, I can hear it gurgling and sometimes it will emit steam but hardly like before, I think I might be switching to a different steam mop I contacted the company now it will take a few days for someone to contact me back, go figure.
Posted on May 27, 2011
Mop turns on but will not produce steam, how can I fix this ?
SOLVED: How to Fix a Broken Shark Steam Mop - YouTube
? 3:24
www.youtube.com/watch?v=Vz8OvV30sHMMar 20, 2013 - Uploaded by ProvenHelper I never used distilled water in my Shark Steam Mop and after a few years, my steam mop stopped producing ...
Oct 14, 2015 | Shark S3101 Euro Pro Steam Mop
Red devil steam mop no steam coming out
Add CLR to water tank. Let it sit for an hr to overnight unplugged. Plug back in, turn on steam to medium setting and wait about 20 minutes. Mine started to steam and I let it steam for 5 min or so. Empty out CLR, add only "DISTILLED WATER" and clean away. Good luck.
Oct 24, 2013 | Euro-Pro Shark Steam Mop - Gray/ Purple...
What canI do to get the steam to come out at full capacity?
Mine won't work too. I opened the bottom and found lots of boiling water residual around the outlet. That is why no steam come out. Even if I cleaned it, steam becomed very little, 10% of original. I would say Dirt Devil steam mop is just gabbage product. I do not recomment anyone to pay $50 to buy no more than one or twice usage!
Oct 01, 2012 | Dirt Devil PD20000 Stick Steam Cleaner
How do i attatch wand to dirt devil simpli pd20000
see the video attached and proceed according:God bless you
Jul 13, 2012 | Vacuums
Machine will not produce steam. Machine will heat up but not enough to produce steam. Help ...
heatman101
;a
Jul 31, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Apr 11, 2010 | Dirt Devil MCE4500 Vacuum
My mop would produce steam. It gets hot but when
heatman101
xxxx
Jan 24, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Need instruction on dirt devil mop vac
May 14, 2009 | Vacuums
Vacuums Logo
144 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
