Question about Danby Dehumidifiers
SOURCE: Dehumidifier Compressor is not working
this unit is very simular to an air conditioner except it has a humidistat instead of a thermistat.. if your handy with a continuity tester unplug the unit find the humidistat and check to see if its open or if its good then call the company at 1 800 322 3848 or contact the web site at [email protected] Good Luck
Posted on May 31, 2006
SOURCE: LG LD65EL Dehumidifier doesn't work properly
What do you have the humidity level set at on your dehumidifier? The average is 65%. Make sure you do not have it set at 75% because if you do this could be causing it to keep the humidity so high.
Posted on Jul 08, 2008
SOURCE: My Danby DDR586R dehumidifier shouts hot air
Here is Danby's official response to a similar question on their FAQ page for Dehumidifiers:
https://www.danby.com/faqs.php?cat=12
Q) When the dehumidifier is operating, is it normal for the expelled air to be quite warm? We find that the dehumidifier is warming up the room noticeably (a finished basement).
A) The warm air that is being expelled from your dehumidifier is normal. When the unit is dehumidifying the compressor is working which causes the compressor to become quite hot. In order to avoid having the compressor overheat, air is drawn by the compressor at a rapid rate and the heat is then transferred to the air which must be expelled from the unit. The warm air will stop shortly after the unit has reached the desired humidity. This warm air should not change your room temperature by more than a degree or two.
Posted on May 22, 2009
SOURCE: Ijust bought a danby dehumidifier ddr5009. The
This dehumidifier is built in such a way that the fan runs all the time;however the compressor works only when it is needed. These infos are not specified in the booklet. It does not work like the old ones.
Posted on Sep 11, 2009
SOURCE: Compressor running very hot but almost no cooling. Fan running
make sure the coils are clean both evaporator and condenser,then if there is a capacitor in the motor circuitry,check this,finally if the coils frost,then clear up and frost and clear up time and again,this is a sign of low refrigerant R134a,and this also will make the compressor run hot
Posted on Apr 09, 2010
Testimonial: "Now I need to frigure out where and how to install the fix"
May 31, 2018 | Danby Dehumidifiers
Jul 30, 2016 | Danby Dehumidifiers
May 30, 2014 | Frigidaire FAD504DUD White Energy Star 50...
Feb 05, 2018 | Frigidaire 50 Pint Energy Star...
Aug 22, 2011 | Danby DDR601 Dehumidifier
Jun 06, 2011 | Danby Dehumidifier
Apr 24, 2011 | Danby DDR4009EE Dehumidifier
Jun 17, 2010 | Kenmore 53701 Dehumidifier
Sep 10, 2009 | Danby Dehumidifiers
Jul 05, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
158 people viewed this question
