Possible or debris need to open up and inspect
The cartridges, yes, sounds like they are nearing their end. As they do shut off, I see no problem in letting them go for awhile; but eventually they will reach a point where they will drip (not shut off completely). Personally I prefer OEM cartridges, not aftermarket.
SOURCE: Having problem with Frigidair PLGF389CCB oven will not lite.
you may need a new gas valve....but i think you should replace the ignitor first. the gasvalve won't open unless the ignitor pulls a certain amp draw to keep it open, since yours is just opening when you hit it, and closing when you hit it again, i believe it is the ignitor
SOURCE: Getting really hot water to the kitchen but only
If some taps have really hot and others luke warm, then you might have defective mixing valve, check valve, or crossover on single handled faucet.
http://waterheatertimer.org/Crossover.html
Crossover can also cause stacking event. Stacking could be part of puzzle.
http://waterheatertimer.org/Stacking.html
Once crossover or check valve or mixing valve problem is solved, if you have really hot water to some taps, then turn down thermostat to avoid scalding.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
Add a comment for more help.
SOURCE: I have a BOSCH 425N
You need to have the flow switch looked at. The low flow of the water to the lavs and the kitchen sink, they all have as small demand next to t bath or shower,
Tom
