Question about Locks & Locksmithing
I have a Cosmo Electronic Safe Model # TB-3E Serial # 6110005835....the batteries have died and I can't get it open. I removed the front plate but have no key..how do I get one?
Posted by Jim Nentwig on
I have a Namson SFT-25EA electronic safe, batteries dead, can't remember where I stored key, can I get into it and be able to re use or do I need to force my way in
A "Trouble key" has been provided in case you forget or lose your security code. Remove the small central panel from the front of the faceplate. Insert the key and turn it counter clockwise. Then turn the knob on the door towards the right. This will manually open your safe. If you lose your key, you may purchase a replacement key by referencing the serial number located under the central panel by the lock.
Feb 15, 2017 | The Home Security
I have a Detroit electronic Security safe and the batteries have died whilst I have been away on holiday. I cant find the key to gain access. Is there anyway I can get into this safe?
notify manufacturer with proper paper work and id order replacement key or key code for a locksmith to cut or notify a lock smith
Jul 30, 2016 | Locks & Locksmithing
My safe, a Cathedral EA15 Will not lock. Any suggestions people?
Instructions
  1. 1
    Enter your code on the keypad located on the front of the safe. Some electronic digital safes require you to input a special character like "#" before and after your code. The safe should either beep, have a LED turn green, or display "OPEN" if you have correctly entered the code.
  2. 2
    Turn the handle to the right within five seconds of correctly entering the code. If you wait too long, the safe will lock and you will have to enter your code ag
Open the safe with a key. Use your emergency key that came with the safe to open it if you forgot the code or if the batteries have died. Remove the key cover from either the handle or the control panel to reveal the lock.
  1. 1
    Enter your code to open the safe.
  2. 2
    Place the electronic digital safe into code reset mode. On some models you need to hold the last digit of the code or press the "*" button to get into code reset mode. Other safes require you to open them and press a small red button on the inside of the door.
  3. 3
    Enter your new code on the keypad and press "#" to finish. Some safes may require you to press "*" or a letter to finish the code. If the safe requires it, enter the new code again to confirm that you entered it correctly.
  1. 1
    Use your code to open the electronic digital safe's door.
  2. 2
    Locate and remove the battery cover on the inside of the door.
  3. 3
    Replace the used batteries with new ones. For most safes, this will require two or four AA batteries.
  4. 4
    Test the batteries. Use your code while the door is open to test the batteries before closing the safe.
Feb 08, 2015 | Locks & Locksmithing
Where can I get replacement keys for GX B0709 digital safe
There might be a code on the key lock. Manufacturers can sometimes furnish replacement keys by the code or serial number of the safe. A locksmith could also pick the lock and make a key. Keys are really essential if the electronic lock fails. If the safe needs to be opened without keys, a pro can do this with minimal damage.
Aug 06, 2014 | Safe International Digital Electronic Safe...
Unable to open electronic safe
Locksmiths say this is how to install sentry safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Mar 06, 2010 | Sentry Fireproof Safe
I have a model 45891 Bunker Digital Safe. Battery
how do i change combination on bunker hill 45891 safe, i have tried every way i can think of.
Oct 05, 2009 | Check Point Network Adapter
Nutool sf20 safe
I need an instruction Manual for a Nutool sf20 safe
Jul 15, 2009 | Computers & Internet
I have a gordon digital electronic safe # P45891, lost combination .how to open it?
Take the single screw off of the entry pad and remove the cover plate. Using the key that came with the safe, unlock the safe. Now, look for a little red button on the inner hinge. Push it in and you will note the yellow led on the the front of the safe turns on. Now, enter a 4 digit code of you choice. This is automatically saved and is the new 4 digit code you press to open the safe.
Jun 30, 2009 | Safe International Digital Electronic Safe...
Small floor safe Sentry Model 3877 electronic lock and key
This manual will answer both of your questions.
http://www.sentrysafe.com/pdfs/OwnersManuals/501664.pdf
Feb 21, 2008 | Sentry Fireproof Safe
Locks & Locksmithing Logo
613 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Chris Walker
Chris Walker
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
