Question about Car Audio & Video
Vx7020 troubles application error : application CE4E01.EXE encountered a serious error and must shutdown.
Literally one after warranty, I received this message and unit stopped working, except the rear view camera.
Posted by Kermit Morris Mpa on
5 Related Answers
Anonymous
SOURCE: Gps Stopped working (Uniden GNS
You hopefully have the mobile navigator software CD that came with the GPS unit. Copy the entire folder and contents of the CD to your SD card (make sure you make a full backup copy of the exisiting software on the SD card first).
John MacLean
Brisbane, Australia
Posted on Nov 14, 2008
Anonymous
  • 5 Answers
SOURCE: aioc.exe has stopped working lexmark 5400
this usually happens when you try using the old cd on a vista os.. most of the time the cd was made to work on xp only since during the time of release of those printer, vista was not yet out of the market.. try downloading this patch ftp://ftp.lexmark.com/driver/inkjet_drivers/AIOCenter_patch
disable user account control first.. you can do this in msconfig on the tools tab then run the patch
chose the right series of you printer.. normally when you run the file it will extract the file and run the patch.. cancel the application after extracting the file..
go to c drive on you computer... look for the folder LxkPatchAIOC
go inside the folder and look for the word aioreg.. right click on it and choose merge...
that should fix the issue..
if in case it didnt work on you... try calling 1-800-lexmark
you can email me at [email protected] for more questions about lexmark
Posted on Aug 30, 2009
Norman Worley
  • 1273 Answers
SOURCE: My Sylvania 7" netbook says;
If you have a SYNET07526, then you have a problem with loading all of your applications and it appears that I.E is a problem. You may want to re-flash your system as that is the only way you can get the full compliment of applications. See my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
You may want to go to www.digitalgadgets and see if you can find the same information.
Posted on Apr 16, 2011
dleemacc
Darryel Hubbard
  • 281 Answers
SOURCE: I have a Tim Hortons
When you turn your laptop on start taping f8 at the same time.The screen will come to a screen that gives you some different options.Use the the up arrow button And highlight safe mode.Hit the enter key.The next screen will give you the option to go into safe mode by choosing yes or doing a system restore if you chose no.I would do a system restore which gives you to pick a bold date on a calender which are different restore points(XP)Vista? I think is the same as Win 7 only go back to the last restore point. You more than likely downloaded an incompatible file that is causing the problem.
You can try to repair your system with the system restore disk that will leave your personal files intact and attempt to fix the system files.If this doesn't work.A full system restore is your only option.Some operating systems come with a restore disk while others have a separate partition on the hard drive.I would suggest you have a geek friend help you the first time or take it to a shop.
You may have to get a hold of of the manufacturer to find out how to access the system restore partisan.
http://www.ehow.com/how_4424376_install-operating-system-computer.html
Here are some free apps that I use.
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?tag=rb_content;main
http://download.cnet.com/Advanced-SystemCare-Free/3000-2086_4-10407614.html?tag=rb_content;main
http://download.cnet.com/windows/3150-20_4-0-3.html?&filter=licenseName=Free&tag=page;page Smart Defrag
Make a back up after your squared away only takes 3 DVDs and you just put them in and your back in business.
I always add this for your information. If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions.
Posted on May 21, 2011
Gale Todd
  • 1116 Answers
SOURCE: application iesample.exe encountered a serious
Iesample.exe is a very vital file that needs to run the dynamic link libraries which provide the continuously running services on your computer. With the help with this file, the entire computer and all programs on the computer can run properly without problems. However, if there is any problem with this file then it will cause problems and result in the annoying iesample.exe error which needs to be corrected as soon as possible.
Causes of iesample.exe error
The iesample.exe error can be caused by a wide variety of problems. Hence, it is very important to understand the causes of the error so as to find out the exactly best solution to fix iesample.exe error. Normally, the iesample.exe error is caused by the following factors:
* Mis-deletion of the iesample.exe files by mistake
* Corrupt dll files
* Malware infection
* Inadequate system memory
* Conflicts among programs
* Incomplete uninstall process
Solutions of iesample.exe errors
1. If you have received a iesample.exe error saying that the file is not found or missing, it is highly advised that you should search your entire computer to see whether you can locate it on your computer. If not, the error must be caused by the missing iesample.exe file on your computer. To solve the problem, you should copy one from other computer or download it from a safe website and place it on your computer. This is what you should first do when receiving the iesample.exe error.
2. If the iesample.exe error message pops up soon after you install a program on the computer, it is highly advised that you should uninstall all the recently installed programs as the iesample.exe error may come from the malicious agents on your computer.
3. Most of the time, why you are getting the iesample.exe error is with the Windows registry. Once the file in your Windows registry is corrupted, and your entire computer might be serious damaged if you cannot fix the iesample.exe error timely. But don't randomly remove any files manually from your registry database attempting to fix this error as it is a very risky operation. At this time, what you need is a professional registry cleaner, such as cc cleaner that can quickly scan, safely diagnose and fix the iesample.exe error as well as clean up your registry at the same time.
In a word, it is highly recommended to simply download and run a professional registry cleaner to scan and fix your computer right now. Believe me! It will fix iesample.exe error and return you a complete faster computer within minutes!
Posted on Jul 02, 2011
How do i fix an application shell.exe error on a pkc0pc - 5.0 gps
your going to have to send it in if it want reboot thats all you can do
Jun 04, 2014 | GPS
Black screen pops up states caution your screen may seem reversed
I'm assuming this is a DVD player or at least contains a video screen. The message you are seeing sounds like the rear camera input has been activated. They give this alert to inform drivers that the view through the rear cam may be reversed. Most cameras have a switch setting to allow this adjustment.
If you do not have a rear camera installed, then it sounds to me like the rear camera trigger has been improperly connected. This is a wire that when it sees a 12-volt signal, activate the rear cam input on the radio. If you do not have a rear camera, this wire should not be connected. You did not give a make/model so I cannot begin to guess the wire color, but look for a wire that is not either black, red, yellow, white, gray, green, violet, or blue (with or without stripes). There is no standard color for this wire. Some Alpine units use orange/white, but on most radios, this is a dimmer wire. Pioneer and Kenwood often use a light purple or purple/white.
Find out what wire is for reverse camera and disconnect it.
Dec 19, 2013 | Car Audio & Video
On starting skycaddy sgx, I get the following message on screen: application servicesd.exe encountered a serious error and must shut down
Find the maual or go to ther website. see if they have a software fix for it if not you are most likely going to have to reinstall the software. Errors like these are startup errors and there is no work around that i know of.
Nov 04, 2013 | SkyGolf SkyCaddie SGX GPS Receiver
How you make the camera work for front view on alpine INEw927hd? How do you connect the camera that came with the unit?
you must buy one of these camera and install one in the front of vehicle and one in the back to inew927hd. read the following (With front or rear camera installation, the screen on the INE-W927HD will automatically switch to your front or rear camera view. For the front of the vehicle connect the HCE-C212F or HCE-C200F and for the rear, an HCE-C210RD, HCE-C200R, HCE-C117D, HCE-C115, or HCE-C104. These camera systems will work directly with the INE-W927HD for a clean and easy install. For camera multi-view control directly from the INE-W927HD, the HCE-C210RD for the rear and HCE-C212F for the front can be used.) camera setuppage1 camera setup page 2 , camera setup page 3 depending on the camera installed certain cameras allow different displays on the video screen ... any more questions email me at [email protected]
Oct 27, 2013 | Alpine Car Audio & Video
Have sony xav-60 head unit trying to install a rear view camera, but having issues getting unit to switch over when in reverse what wires need to go where camera has yellow video output 1 red wire, 1 black...
You might try the truly wireless QuickVu(TM) Wireless Backup Camera. Run the yellow RCA cable from the receiver to your Sony unit, if it has an RCA input. The QuickVu camera has no wires, so that part is really easy. Buy direct from the manufacturer!
Aug 12, 2013 | Sony XAV-60 Car Video Player
Car Audio & Video Logo
307 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
