Question about Whirlpool Dishwashers
Your water will not get hot because your control board since there is no water been coming into the dishwasher and turn the heater off you need to run the diagnostic mode fix the problem and that should take care of the issue
Posted on Jun 04, 2019
SOURCE: Dishwasher Dishlex DX302WB No Hot Water
Thank you This worked for me!
The heater was ok found dry joint on pc board
see attatched photo
Took top 6 screws out of door holding front panel in place
Removed front switch panel
I then labeled the 6 cables with 6 being for the heater
Removed pc board from housing to find dry joint
using small piece of wire and solder repaired board
re assembled
now as good as new
Posted on Jun 14, 2008
SOURCE: Whirlpool dishwasher heating element overheating
Same thing just happened to my yesterday on my Kenmore. Expert help needed.
Posted on Dec 04, 2009
SOURCE: Miele G661 Dishwasher heating element
Loosen element-retaining bolt plus clips in dishwash chamber. Upend machine and take base off (held by four crosshead screws). Disconnect spade connectors from end of element and gently tap/push old rubber block through. Element will drop out with retaining rubber.
Hautebrian.
Posted on Jan 21, 2010
SOURCE: Miele dishwasher not heating
hi,
you would have to turn the unit on it's side and remove the bottom plate and check with a multi meter the resistance of the heating element to see if the heating element is defective. i doubt the dishwashing liquid caused a fault other than causing the unit to over sud and spill water into the base. You could remove the panel under the door and have a look and see if you have flooded the base. if you have a float switch in the base (white polystyrene disc and switch) this will stop the unit from working as well. dry up any water and try it again. hope this helps and don't use the dishwashing liquid in the unit.
Posted on Jan 22, 2010
SOURCE: hi my miele dishwasher g665 no hot water or drying
new heating element
Posted on Jan 27, 2010
Aug 28, 2011 | Ariston Technologies Dishwashers
Sep 30, 2010 | Whirlpool Dishwashers
Jun 28, 2010 | Dishwashers
May 20, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
May 05, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Nov 08, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Mar 30, 2009 | Dishwashers
Mar 20, 2009 | GE Dishwashers
Jan 20, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dec 19, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
147 people viewed this question
