Call the manufacturer support line. They should be able to tell you where to get one, if not off them. If it's an older model and the manufacturer is out of business, try looking on eBay.
Posted on Jun 03, 2019
Wear and tear or improper usage
SOURCE: what will a stihl 015 chainsaw do if one of the
I am not very knowledgeable about Stihl but I know this one is out of production and Stihl is no longer supporting it. You can find a group of avid chainsaw enthusiasts here:
ArboristSite.com Chainsaw thread (free to join) http://www.arboristsite.com/forumdisplay.php?f=9
Please do a search for your saw. There are many Stihl threads. Someone probably has the parts you need. If not your saw may be worth quite a bit as parts.
Lou
Posted on Jan 16, 2010
SOURCE: repair manual for Stihl TS
my decompression valve camp lose how can i get to put back in
Posted on Jun 10, 2011
SOURCE: Makita concrete saw, no spark, new ignition coil.
Check clearance between the coil and magnet, too far away and magnetic field won't generate.
Posted on Apr 13, 2012
SOURCE: stihl madel ts420 how to change air filter
There are 4 torx screws on the black back cover. Here is the owners manual. It is explained on page 33.
Stihl TS420 owners manual
Posted on Aug 25, 2012
SOURCE: How do I gap ignition module on a TS350 Stihl concrete saw?
I thought the unit was under the flywheel, in this case there is no gap to set it just screws to the crankcase and you re fit the flywheel.
Posted on Sep 21, 2012
Jul 18, 2017 | Stihl Saws
Apr 30, 2017 | Garden
Jul 12, 2014 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Feb 17, 2014 | Stihl Garden
Sep 18, 2012 | Stihl Chainsaw Cutoff Saw Flywheel 08 S...
Aug 13, 2012 | Stihl Concrete Cutoff Chop Saw Clutch...
May 30, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
Nov 13, 2010 | Stihl Concrete Cutoff Saw Flywheel Magneto...
Jan 11, 2010 | Garden
May 08, 2018 | Stihl Saws
141 people viewed this question
