I would like to connect 2 powered stage monitors, not sure where the inputs go. Second part of question, is the Sub in the correct input? Thanks! Keith
SOURCE: Power Saving Mode problem using the DVI input. VGA input Ok.
try the display on another computer, if the display does the same thing on another machine, then its definitely a problem in the display not in the computer drivers or bios.
SOURCE: No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
Maybe some changings/modification will help you too.
Stefan
SOURCE: Conncect powered subwoofer to passive subwoofer wires???
It will work just fine.
Testimonial: "Thanks."
SOURCE: Video input: 2 D-sub No signal /Video input 1 DVI-D No signal
Below is a link that may help you...Good luck http://www.techspot.com/vb/all/windows/t-35070-DVI-to-DVI--No-Signal-on-LCD.html
