Question about LG Refrigerators
My LG icebeam door cooling refrigerator freezer is not working I changed the fuse as well.
Posted by Kamini Patel on
Kenneth Simmons
  • LG Master
  • 1,118 Answers
I am think your problem is it is not coming on. If that is right my first thoughts do you have power to refrigerator. Check breaker or fuse in house electrical panel which powers the refrigerator outlet. Try turning the breaker off and back on . You might try unplugging the refrigerator and plug something else into the outlet to see if it will work if you do not have a volt meter. You said you changed the refrigerator fuse was it blown and could it have blown the new fuse.
If it has power but is not working there are a few you tube videos for help with several issues. I searched for( LG ice beam door cooling refrigerator freezer not working) and picked these two you can look for more.
https://www.youtube.com/watch?v=ThLYEwCs800
https://www.youtube.com/watch?v=YNwcwOtCB70
Posted on Jun 02, 2019
5 Related Answers
robert samples
  • 1314 Answers
SOURCE: LG refrigerator not cooling
open your freezer and hold down your light switch see if you hear a fan running next look on the back wall of the freezer see if it has heavy frost and reply to me with answer but dont rate me till were done lol
Posted on Jan 02, 2008
Anonymous
  • 255 Answers
SOURCE: lg ICEBEAM GRS512GC. Freezer cooling but fridge
check to see if fan inside freezer is running.
is the evap coil in freezer froze up ?
if fan is running and coil is froze up u need a defrost timer.
Posted on Sep 24, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: LG refrigerator freezer is not working, its not
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
aeryeqr
Posted on Sep 29, 2010
absabid
SOURCE: LG Fridge Icebeam Door Cooling
lg ice beam refrigerator which has door cooling also is not cooling properly. the freezer is working there was ice accumulated in the rear corner of the freezer i defrosted but still the fridge is not cooling and there is a pool of water at the bottom most of the time. sometimes i see the fan inside the fridge is not working
Posted on Feb 12, 2011
forum2009
SOURCE: LG icebeam door cooling
bon jours;
SVP j'ai un probleme , mon LG réfrigérateur a porte ice beam ne. fonctionne pas correctement.Aider moi a trouvé une solution
merci
Posted on Jul 25, 2011
Hi there I have an LG Icebeam Door Cooling fridge that doesnt seem to be working correctly. The fridge is not that cold and the freezer is defrosting on the top section. The light is on and it seems
Find your model # and put it in the search box here: http://www.lg.com/us/support . Once your fridge is showing, there is great troubleshooting info available. Also, armed with the model #, we can actually give you pertinent advice!
Nov 24, 2014 | LG Refrigerators
Could be your thermostat is defect, but even more likely the compressor is not working correct. Perhaps you even lost the cooling fluid. To be sure, please move everything as quick as you can to another fridge and ask a technician to have a look.
Lg Icebeam Door Cooling fridge/freezer top of freezer not freezing
is the fan not working in it..may be jammed up..we had an old unit that did this all the time.. the door seal was bad allowing house humidity inside and it wpuld frost up so bad the fan got stuck..we eventually bought another used unit..
Jan 20, 2014 | LG Refrigerators
Error fs or f5
Here is the LG LRSC26930TT Service Manual=> HERE When using this manual scroll to page 28 in the PDF. Code fS is #1 abnormal Freezer Sensor, Freezer Sensor Short Circuit. Most likely the sensor needs replaced yet test can also be done to prove this fault as you read from Service Manual what and how to test. I will be here to answer any questions you may have. Here is a location=> LRSC26930TT Freezer Section part location 400A Sea Breeze
Part=> LRSC26930xx Freezer Sensor/Thermistor
I will be waiting should you have other Technical questions, Thanks, Sea Breeze
and Thanks, For Using Fixya
Jun 03, 2011 | LG LRSC26930TT 36" 25.5 Cu. Ft....
LG Fridge Icebeam Door Cooling Refrigerator Freezer is leaking water into very bottom of fridge. Fridge is only 6 years old. What could be the cause of this problem ? Many thanks for feedback.
Jan 11, 2011 | LG LRTN22310 Top Freezer Refrigerator
LG ICEBEAM GRS512GC. Freezer cooling but fridge not cooling. Just had tech replacee fridge pcb with no sucess... any suggestions? thanks in advance :)
Sep 23, 2009 | Refrigerators
My LG freezer is cooling while the refrigerator doesnt.
OK THEN FROM WHAT YOU SAY SINCE THE FREZER WORKS BUT NO FRIDGE IT SOUNDS LIKE A DOOR SEAL FOR THE FRIDGE DOOR GONE BAD,DIRTY,WARPED,OR WORN OR THE DOOR IS'NT SHUTTING ALL THE WAY THIS IS THE NEXT STEP OF WHAT TO LOOK AT
Apr 12, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Jan 02, 2008 | Refrigerators
Normally the fans get turned off when you open the door so it does not blow all the cold air out. The fans should only run when the doors are closed. Push in the door switch and see if the fan works then (of course it has to be in the middle of a cooling cycle or the fans still won't run).
Dec 01, 2007 | Refrigerators
Refrigerators Logo
47 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
