Question about Acer Tablets & eReaders
My grandsons Acer tablet will turn on but he can"t open it..
Posted by Kim Graves on
I got my grandson a tablet from your company now it won't charge!
not from fixya site did you get a tablet
contact the supplier direct for information on a warranty replacement
How to save a network password on an Acer Iconia one 7 tablet
It saves it automatically, unless you say "forget" Wi-Fi website.
What would be a reason for my ACER Iconia A1-810 tablet not powering on with a full charge?
If it doesn't turn on with a charged battery, you may have a broken logic board. If you're out of warranty, somebody has to open the device and replace the logic board. The part is available on ebay. On youtube you will find a guide on how to disassemble an Acer tablet. Maybe a tech savy friend can do it for you. If you want to pay to have somebody do it for you there are third party Acer Tablet Repair Services.
How can i remove the locked screen and password my grandson can't remember
Yep, that is how password protected tablets work. How about letting us know what brand of tablet you are trying to hack into.
5helpful
2answers
How to reset kurio tablet? Won't turn on at all
my kurio tablet wont turn on, i have tried charging it and turning it on , and answers on google
2answers
Acer tab A200
You may have to perform a reset if your tablet fails to respond when buttons are pressed or the screen is tapped. To reset your tablet use a small thin object (such as a paperclip) to press the recessed reset button.
Or do Clean Boot to restore the Acer Iconia Tab A501 factory default settings.
  • Open Settings from the application menu, then tap Privacy > Factory data reset.
  • Click Reset tablet and then Erase everything to format your tablet.
When i turn on my pc it ask for a password i never created, how do i fix this problem
Hello again sounds like it has lost its bios configuration and wants the CMOS re-setting check the hard drive hasn't come loose or your CD if it is an interchangeable one .. and if the floppy drive was in the machine ( not a disk an actual changeable drive ) .was in the last time you shut it down put it back in and reboot see if it's ok unlikely but worth a try
So if no joy you will need to remove the CMOS battery probably located under the keyboard .. or sometimes behind the ram module underneath and a few machines have their own battery holder under the machine .. its silver looks like a large watch battery and is in a plastic holder .. don't touch it with your hands they are static sensitive as are the other components around it .. wear a pair of marigolds the rubber will help protect the circuit ... hope this is a success for you good luck .. Regards Vortash
Tablets & eReaders Logo
Top Acer Tablets & eReaders Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
NOEL
NOEL
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
