Question about Cycling
How do i fix eror message e014 to shimano steps sc-e6000?
It is a computer to My e-bike white street comfort sc-e comp
Posted by Mats engqvist on
2 Related Answers
suhail aabed
  • 109 Answers
SOURCE: Eror E014?
The fixing motor is faulty. The DC controller PCB is faulty.
Posted on Mar 20, 2010
Paul Bade
  • 1666 Answers
SOURCE: Topic : "Shimano DuraAce Di2 ST-7970" and the
It is apparently critical for the success of the pairing operation that initial power-up of the component to be paired be done cleanly, with little or no contact bounce when the battery is inserted. Since this is done with low power high frequency radio signals, interference and reflections can be an issue. If you have extraneous gear such as metal water bottle brackets mounted near the system controller / battery pack, remove it for this operation. Do not let anyone play with R/C toys within 30 feet while you are doing the pairing, and turn off Bluetooth devices to be really sure.
  1. Remove the batteries from all components of the system except the SC-7900, including the heart rate monitor and the speed sensor. Wipe the battery contacts of the shift system with a cotton swab moistened with isopropyl alcohol (get straight alcohol if you can, rather than the 70% rubbing alcohol mix). Clean the battery terminals with a clean paper towel moistened with isopropyl alcohol.
  2. Click the shift buttons on each lever, then use a piece of wire or suitable tool to short the battery contacts of the shifting components (NOT WITH THE BATTERY INSTALLED!) for 10 seconds. This will ensure that any power bypass capacitors in the system are fully discharged and the circuitry will completely reset when the battery is put back in.
  3. Set the SC-7900 into pairing mode as described in the manual (latest version can be downloaded here). I suggest removing the SC-7900 from its bracket and parking it someplace where you can conveniently grab it when you reinstall the battery in the shift system.
  4. If there is a power switch on the system, turn it on first. Push the shift system battery into place smoothly and hold it. If you can lock the clamp in place while holding the battery so it does not slip even a little bit from the contacts you may do so. Do not give it a second push "for insurance" at this time; this may generate a contact bounce.
  5. Immediately press the Select and Set buttons on the SC-7900 to put it in scan mode and hold the SC-7900 about 1-2 feet (30-70 cm.) away from one side of the bike. The pedal on that side should be in the lowest position to minimize any effect of radio signal reflections from it.
  6. If the pairing does not complete, remove the battery, then disconnect the electrical cable from the rear derailleur. Repeat step 4 and press "retry" (the Select button) on the SC-7900 to repeat the scan. If this works, the front and rear derailleurs are separately paired devices. In that case, remove the battery again, reconnect the rear derailleur and repeat the scan.
  7. Once the shift system is paired, you can pair the heart monitor and speed sensor. Note that all of this must be done in one pairing session. Do not exit the pairing mode until everything is paired, or you will have to start over.
The graphics shown in the SC-7900 supplemental manual imply that the right and left shift levers are separate devices, but they are powered from the same battery and connected to the system at a single point. While Shimano's online documentation on this is rather sparse, the Di2 7900 system description says the system logic and communication circuits are inside the front derailleur. I do not expect step 6 will be needed. If you go through step 6 and it doesn't work you may need to disconnect the shift levers individually and try again. Once a device is paired, you should not have to disconnect it or remove power from it to continue the process with other devices.
If none of this works to pair your shifting system with the SC-7900, then the wireless circuitry in the shift system is defective (as I mentioned previously, this is probably in the front derailleur). Even if it is out of warranty, you may be able to get a warranty replacement since it is a newly discovered defect that could have existed from the factory. You will probably have to talk directly to the Shimano service department for this.
Posted on Jun 11, 2011
How do i adjust bike breaks so they will not rub
each type of brake has several adjustments to it, but these vary by model and style.
If the brake only rubs in a spot or two, more likely the rim is out of true.
Oct 01, 2014 | Next 26" Avalon, Comfort Bike, Full...
Tip
Identifying Your Schwinn Airdyne
How To Identify the Model of a Schwinn Airdyne Exercise Bike
  • We'd like to share some characteristics of the Schwinn Airdyne bikes that can be used to help you identify the model of your Airdyne bike.
What size/type fan does it have? Is it a spoke fan like a bicycle wheel or short wide blade fan?
Does your Airdyne bike have two chains or a chain and a belt?
  • AD3, AD4 bikes have two chains.
  • AD Pro/Comp and AD Evolution Pro/Comp bikes have a chain and a belt.
How do the crank arms attach to the Airdyne, by wedge pin or bolt?
  • AD3, AD4 and certain AD Pro/Comp crank arms attach by wedge pin.
  • Certain AD Pro/Comp bikes have crank arms that attach by bolt.
  • AD Evolution Pro/Comp bikes have crank arms that attach by bolt.
How To Identify the Model of Schwinn Airdyne Bike
on Mar 11, 2015 | Schwinn Original Airdyne
Why is my Yamaha FZ750 Genesis blow white smoke?
If it is liquid cooled it has blown head gasket or a craked head or cylinder.first thing to do is find out wat is the cause to determan the fix....
Aug 20, 2012 | Yamaha Yamaha Fz750 Motorcycle Cover Bike...
How do i change the settings on a topeak comp 150 bike computer
You can download the manual from Todson Support They own Topeak.
Dec 06, 2009 | Cycling
Can i change exhaust on 09 dyna street bob to short shots without doing any other changes
On the '09 bikes, you can't change anything wihout messing up the computer so I'm told. I don't work on the computer controlled bikes because of this. So, basically I only work on the older bikes, 2000 and before. Just go to your local Harley shop or independent dealer and talk to them. But my dyno guy says that the only way around the factory computer is something like a Power Commander or other "break out box".
Oct 20, 2009 | 2006 Harley Davidson FXDBI Street Bob
How do i connect a panasonic theater system to asylvania tv
For best results either use an s-video connector and RCA Red/White for the audio. If no s-video available, use comp which means composite (Red,Blue, Green) so the truest color can go from one unit to the other. On the back of the theatre system, plug everything into "output", on the panasonic, input.
Dec 31, 2008 | Panasonic 600W DVD+VCR Home Theater System...
Cycling Logo
457 people viewed this question
Top Cycling Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Bill Boyd
Are you a Cycling Expert? Answer questions, earn points and help others
