Cell Phones Logo
How to remove sim from huawei b618 - Huawei Cell Phones
I want to use another SIM card on the land phone Huawei ETS2258
To Use another sim card you have to unlock your huawei ETS2258
Here is the direct link to unlock you Huawei ETS2258
Official Huawei IMEI Permanent Unlock Important Select the Current Network...
Ascend y330. Where can I get free SIM unlock code?
http://sim-unlock.net/simlock/Huawei/Y330
How to unlock Huawei Y330 by code?
Unlocking Huawei Y330 by code is very easy, it is also safest and non-invasive method of unlocking your phone. To get code for unlock Huawei Y330. You need to provide IMEI number of your Huawei. Type on keyboard *#06# or remove battery from your Huawei Y330 to check IMEI number.
To unlock Huawei phones you need to provide them with IMEI number and model of your phone.
Huawei Unlocking process is safe and easy.
WEAR IS SIM CARD SLOT FOR HUAWEI M 835
1.Carefully push the SIM card out of the wallet-sized plastic card carrier.
2.Turn your Huawei M835 off.
3.Grasp the notch at the top of the back panel and pull away from the Huawei M835 to remove the back cover.
4.You'll see a notch at the top of the battery.Use it to lift the battery out of the Huawei M835.
5. Your SIM card has one corner missing.Slide the SIM card into the SIM slot so that the corners match.Ensure that the gold contacts are facing downwards.You will hear a click.
6. Reinstall the battery and back cover and then power up the Huawei M835
I know my huawei y300c imei 869046013276947 for
To remove sim network unlock pin from your Huawei y300, use unlock code . You can get it from any of the online vendors like WickedUnlock.com to unlock it .
Nov 12, 2014 • Cell Phones
How to get sim unlock code for huawei ascend y300 free
To remove sim lock from your Huawei Ascend y300, use unlock code . You can get it from any of the online vendors like Unlock-Zone.com to unlock it .
Aug 17, 2014 • Cell Phones
Sim lock code for Y301 Huawei
What's your exact mobile model no?Did you mean you want to remove sim lock from network lock?
Yes means visit MobileUnlockSolutions.com Here you can unlock your Y301 Huawei phone at low cost.
May 30, 2014 • Cell Phones
Yes means visit Unlock-Zone.com Here you can unlock your Y301 Huawei phone at low cost.
3helpful
I need the np code for my phone huawei g6600 imei:357510038839608
To get the NP code for the Huawei G6600 model Phone You can reach here
Theunlockspot buy the code at reasonable cost and Unlock it from Network provider lock,then NP code means Network provider or Unlock code to remove the Network lock,after Unlock Your HUAWEI G6600 you can use any GSM Network Sim in the Phone......To Unlock it follow the steps or instructions below:
Huawei G6600 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Huawei G6600 mobile phones. If you enter over a certain amount of wrong unlock codes on your Huawei G6600 mobile phone, your phone may get hard locked and sometimes become unusable.
If your Huawei Device is a mobile phone:
1.Switch on your Huawei Phone using another networks SIM card.
2.Your phone should ask for an unlock code(NCK Code).
3. Enter the unlock code we sent you.
Top Huawei Cell Phones Experts
NOEL
NOEL
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
