417 front loader washer - door doesn't register as closed, washer won't start all lights are lit except "door locked" of course I"ve tried to close door fully, unplugged, etc. but no go
Common error with front loaders is the door interlock. Make sure the door is positively closed. A gentle open hand push at the erea of the door lock often gets a machine started.
Front load washers won't fill if the door is not closed and locked. Listen for the door locking when starting a cycle, then pull on the door to make sure the door is closed and locked.
Delayed Start Feature
Some washers have a delay prior to filling, where the electronic control is checking the dispenser function. This is Normal.
Flashing Lights or Error Code on Display
When there is a filling issue, the washer may shut off and display one of the following codes: LF, LE, nF, IE, FH, E10 or F20.
If the washer is displaying one of the above error codes, then do the hard reset procedure listed below.
If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
Unplug or turn the circuit breaker off for 30 seconds.
Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
Press the Pause / Cancel / Stop button twice to clear the display.
Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
the model # would be very helpful in diagnosing the problem it usually is on a label on the rim inside the door and sometimes their is a second label on the back of it
This could be one of two things. The actual door lock assembly there is something malfunctioning with the part that the striker goes into or that the control pannel is not registering that the door lock is actually closed. One is a $60 fix (the door lock) and the other is approx ($250). Unfortunatly because they are both electronic parts you can't just buy the cheap one put it in and if it doesn't work return it. Most stores have a no return policy on electronics/electrical parts.
