Question about Radio Communications
I can't get my Vox AD15Vt to switch back to manual mode. It seems to be stuck in some kind of pre-set. Please I need Help.
Posted by jim cesena on
5 Related Answers
sharcnet
SHARCNET-USA
  • 2130 Answers
SOURCE: stuck with pre boot mode on screen
"Will not turn off, stuck on with display saying 'pre boot mode'. Does nothing but this - please help!"
This indicates that the on/off switch is shorted out. You can duplicate this problem by taking a working Nuvi and keep holding down the on/off button when turning it on. It will stay in this mode until you let off on the power on/off button.
- Jim
Posted on Aug 12, 2008
Anonymous
SOURCE: Picture Mode reverts always to Dynamic after several minutes
The set was a store demo, and the options were set so they could not be adjusted. On instruction from Samsung I pressed MENU and VOLUME buttons on the side of the set and hold for 7 seconds The display reverts to Standard from Dynamic. The Remote Options button showed Store Demo, but now shows Standard. All memory functions seem to function now. Thanks for your help.
Watty2c
Posted on Jan 17, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: I have model 2271 PAG 40 it seems to be stuck in
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals.Rate me, please
Posted on Mar 22, 2010
blackmar
Martin Moody
  • 235 Answers
SOURCE: Gaggenau EB944-110 Pyrolytic oven stuck
Yes this could be the problem. If you can't set the timer to manual mode the oven will not work. Turn the oven to on so that when power goes to it you will see the oven indicator light come on. Play with the timer buttons until the oven indicator light comes on. If it won't work you probably need a new timer.
Posted on Feb 12, 2011
pctech1
Jeremy Moore
  • 1940 Answers
SOURCE: I can't seem to be
Check your Wiring, as it sounds like your Constant +12 volt wire is connected to the Switched +12 volt wire. This would cause all settings to return to factory, just like when you lose power due to a bad battery or battery disconnect. Since you switched off Demo mode, and it comes back, this has to be a wiring problem, or a defective unit, but more than likely a wiring problem. On most pioneer units, the Yellow wire is the Constant 12 Volt (battery) and the Red wire is the Accessory 12 volt (switched).
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on Mar 14, 2011
I have a VOX NT15. When switched to Triode ( 7,5 W ) mode, my amp generates quite loud buzzing sound. The loudness of this sound is on the same level, no matter if the volume is switched to minimum or...
You LIKELY have a bad filter capacitor. The additional load of the Triode load is probably dragging the supply causing flattopping and the power supply ripple frequency to come through. Have the unit serviced.
Jul 26, 2011 | VOX Amplification Vox Night Train Amp Head
How do you disable the VOX setting on a Talkabout MR350 2 way radios. I wan to use it with a headset, but do not want VOX on.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/MR350-351%20User%20Guide%2012-16-08%20KEM-PK14190-90.pdf You will find the instructions for VOX and iVOX on the bottom of page one, and at the beginning of page 2.
Be certain when plugging in your audio accessory that the radio is turned off. If the radio is left on inadvertently, you would have no control over the VOX settings, it would immediately be in a confused VOX mode.
Also, with most Motorola radios, if VOX begins to occur, turn off the radio, and then re-insert the audio device plug. And in some instances, pressing the PTT on the radio when you are having a VOX occurrence will put the radio back to push-to-talk status.
Best regards.
Feb 19, 2011 | Radio Communications
Gaggenau EB944-110 Pyrolytic oven stuck in some kind of mode after power outage. Oven worked perfectly but there was a mains cut. After restoring power it appears to be stuck in some kind of strange...
Feb 11, 2011 | Ovens
Need code for euro-vox max
i have a euro-vox max v, the other day i lost some channels and now those channels instruct me to insert smart card.
my box usually updates on its own but dosnt seem to be now, can you help me with this problem please.
May 27, 2010 | StarTech.com StarView SV211K 2-port KVM...
Okay on my 2 way radio i turn wox on and then turn the radio off plug the headphone in turn the radio back on and then the vox is turn off again
you miss to save your last program,after you turn to vox mode you must to save ,or the mode will back to before you change
Feb 27, 2009 | Motorola Talkabout SX700 2-Way Radio
Stuck with pre boot mode on screen
- Jim
Jun 07, 2008 | Garmin Nuvi 660 GPS Receiver
Cobra PR4100-2 WXVP with VOX
Hi Dave,
On some other models/brands, you need to use an external mic/spkr such as a headset for the VOX to operate. This may or may not also work for your model. Perhaps you can try getting hold of a headset that will fit your model and see if it works.
If you are already using a headset:
1. If it is a compatible model, then something is wrong electronically with your unit and you will need the services of a qualified communications technician;
2. if it is a generic or some other brand/model, then the pins, jacks, plugs or connectors may not be wired to be compatible with your Cobras. You need to get Cobra compatible ones.
Hope this be of some help/idea. pls post back how things turnes ouot or should you need additional information.
Good luck and kind regards.
Dec 26, 2007 | Cobra 22 CHANNEL 2-WAY RADIOS
Operating Manual
To turn off sound activation press the menu button 3 times to enter VOX mode. The VOX icon should be flashing, then press the down button till the number of bars dissappear. Press the menu button to confirm the VOX off mode. You also can adjust the sensitivity of the VOX mode by how many bars are displayed, less bars equal less sensitivity. No bars and voice command is deactivated. Hope this helps. Ed
Dec 11, 2007 | BellSouth 2250BK (22 Channels) 2-Way Radio
Bell South 2250 one seems to be voice activated and other not voice activated.
Nov 24, 2007 | BellSouth 2250BK (22 Channels) 2-Way Radio
Unwired UFRBS10 2-way radio
I tried to find the user manual but no results mostly of the FRS radios, has a menu wich incluides the Vox feature, please tell me if you have a little face icon, this could be the Vox field to turn on or off. Or tell me what icons you have on it in the menu
Mar 01, 2007 | Unwired UFRBS10 (14 Channels) 2-Way Radio
Radio Communications Logo
136 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Radio Communication Expert? Answer questions, earn points and help others
