Question about Fujitsu Heating & Cooling
Timer light flashes twice no heat ,works on cold only
Fujitsu heat pump awtz24lbc indoor and aotz24lbt outdoor unit
Posted by Ian Fowlie on
5 Related Answers
Anonymous
SOURCE: Fujitsu Heat Pump - problems
I had the same problem. The heater did not work in heating mode. However it was OK in air-conditioning mode. The operation light and the timer light blink twice and then the operation light blinks for 5 times followed by few seconds non blinking, then the cycle repeats again. I have read on the internet that you better unplug the power cord and then plug it again so that the heater re-sets itself. My only problem was that my heater is directly plugged to the power with no visible plug. So I went to the main distribution board and put off the power for about 20 seconds for the whole home. HOORAY!! The heater worked after that.
Posted on Aug 08, 2008
Anonymous
SOURCE: i have a Fujitsu ASTA24LCC
Check your filters. Manual says they need to be cleaned every two weeks under normal operation (and in my case more often during renovations). It seems it may not take much to limit air flow enough for the indoor unit to trip out. Hope this helps.
Posted on Aug 24, 2008
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
Posted on Jun 01, 2009
SOURCE: fujitsu asya09lcc wallmount split lights flashing indoors
just happen to me, call the service guy........... he told me to cut power for 30 minutes cause it erase memory inside machine. I did and its working........ So happy
Posted on Jan 05, 2012
jasondonohue
jasondonohue
  • 6 Answers
SOURCE: Timer light on fujitsu heat pump flashes not heating
the light flashing indicates there is a problem. you can try reseting the system by turning the power supply off and back on again 30 sec later, if the same thing happens you need to count the number of light flashers and that relates to a fault code
Posted on Jun 20, 2012
Fujitsu ASTA12LCC WILL NOT HEAT OR COOL. GREEN TIMER LIGHT FLASHES TWICE AT INTERVALS. FAN WORKING. IS IT REPAIRABLE?
Serial signal reverse error. Basically the outdoor unit is not talking to the indoor unit. This is normally due to damage to the outdoor controller PCB and it needs to be replaced.
Jul 03, 2017 | Fujitsu Heating & Cooling
Fujitsu a/c outdoor model number AOTG12LVC indoor unit economy light flashing continuously, operation light single flash, timer light single flash this sequence repeats
Serial communication error. This means that the indoor unit is not communicating with the outdoor unit usually because the outdoor unit is faulty. You can check the indoor unit by switching it to 'fan' mode and seeing if all functions work normally (fan speed, louvers move as directed). If it responds normally, then it's probably ok so you can turn your attention to the outdoor unit. A common problem with the outdoor controllers is that they are susceptible to bugs, geckos, etc. shorting them out which will mean replacement of the board.
Mar 05, 2017 | Fujitsu Heating & Cooling
How to fix Fujitsu a1 error code for 15rls2 heat pump.
Try cutting power to the indoor and outdoor units for a couple of minutes. Restore power and see if the error returns. The A1 error for this line of units indicates high compressor discharge temperature, which translates to overheating outdoor unit.
If this error code remains after a hard power reset, it's time to pick up the phone. Either you have a refrigerant leak which has resulted in a loss of freon, or a blockage in the refrigerant plumbing that is backing up pressure in the system. Both conditions will require a major repair by an authorized service tech to get your heat pump up and running again. 25361378-awph1b3yhxdrnyqdcrsrelkr-4-0.jpg
Please mark my answer as helpful.
Jan 09, 2015 | Fujitsu 15RLS2 Halcyon Wall Heat Pump Air...
How do I use the heat on my Fujitsu ASU15RLS2?
there is an outdoor unit and is probably low on Freon and not working. it probably needs service. if the indoor unit come on, then the outdoor unit has power but may be low on Freon.
Nov 16, 2014 | Fujitsu ASU15RLS2 Single Zone Wall...
Fujitsu heat pump flashing code?
Test the fuses for the outside unit.
Aug 29, 2017 | Heating & Cooling
Indoor fan slow to rotate in heat mode and no heat/compressor
The indoor fan will not run at normal fan speed untill the indoor coil reaches 32oC. This is done so that a cold draught is not felt when outdoor unit is not running. Check to make sure the outdoor unit is operating. If the outdoor fan is running but there is no indoor fan after 5 mins then you must likely have a gas issue or a fault compressor circuit.
May 31, 2010 | Fujitsu 24R1 Air Conditioner
Have just installed a Fujitsu Asta 24lC air con heat pump problem
Hi Shannon,
I would pursue your fight with Fujitsu, normally their units are reliable:(
It could be a really simple problem or a really complex one ranging from many componenets. A air conditioner has many more components that people may think. Keep fighting to get the unit repaired will it is still under warranty, after that Fujitsu wont want to know you. It could also be a wiring and refrigerant fault. Call Fujitsu out again.
I take the time to answer your question, so please rate me.
Thankyou Mat
Aug 24, 2009 | Heating & Cooling
Split unit, I get heat but no cold
I have run into this with the LG brand systems. try shutting power off to the outdoor unit to reset all units. If problem persists, it could have to do with a charge level of refrigerant (freon) or possibly a failed control board.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cody_17f08cf8e340c06c
May 16, 2009 | Fujitsu 24R1 Air Conditioner
Outdoor not workin
the outdoor unit is totally dead or only to the heat mode?if it is to the heat mode propably must check the refrigirator.if it is too the cool mode the plate has problem.if is multi check the outdoor plate in other occasion check the indoor plate.
Mar 28, 2009 | Fujitsu Heating & Cooling
System will not start up.
This is a signal fault between the indoor and outdoor first make sure the dip switches are set start with the unit closest to the condensor set as unit 1 then next unit as 2 and so on the dip switches are inside the indoor unit on the pc board if you check the manual it will tell you which swithes to set, if this wasnt done when the units where installed they would have never worked i would also check the signal wiring between the wallmount and the splitter box / bc box and make sure there isnt a loose connection when you have ruled this out id say more than likely it is a faulty indoor board on the wallmounted unt
Jan 27, 2009 | Fujitsu 24C1 Air Conditioner
Heating & Cooling Logo
Top Fujitsu Heating & Cooling Experts
Marvin
Marvin
Dan Webster
Dan Webster
jdthefixer
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
