Question about Health & Beauty
My strider st 1 blue fault light keeps coming on can you please give me advice on what could be causing this problem
Posted by Carole Harris on
Strider maxi charger flashes continuous while plugged in , the 3 diagram lights
Hi have u tested you're batteries u can buy a BATTERY LOAD TESTER ON E/BAY. OPROX PRICE $35. THIS WILL GIVE U an accurate reading on there condition .....Cheers
Jun 16, 2016 | Electric Strider Maxi 4 Wheel Mobility...
Fault light and hazard lights and horn on continuously
hi, Has it got wet ?
If so water collects at the bottom of the switches making a connection, to fix carefully remove the base of the switch and dry, beware here will be a lttle string in there plus bits of plastic... so beware...
Regards
www.gewizrepairs.co.uk
Nov 19, 2013 | Electric Strider Midi 4 Wheel Mobility...
Is there a website to download fault codes on a days strider mobility scooter ?
www.ctmhomecare.com/PDF/.../Troubleshooting-Scooter.pdf This link will give you the fault codes for aCTM scooter but all are standard codes and should apply to your scooter also. Hope this helps
Mar 01, 2011 | Electric Strider Midi 4 Wheel Mobility...
The brushes in the electric motor of my strider midi 4 plus mobil
This could be caused by the commutator not being smooth and causing undo where on the brushes
Jun 06, 2010 | Electric Strider Midi 4 Wheel Mobility...
I have a problem on my mondeo st tdci withthe
hi check your coil first if this faulty it can cause all these problems please rate this answer good luck
Nov 19, 2009 | 2005 Ford GT
No drive,flashing green light
Are you sure the FREELEVER is in the right position ? , to test try to push the scooter ?
Battery Low ?
Mar 12, 2009 | Electric Strider Midi 4 Wheel Mobility...
My wifes strider chair runs a bit the stops. Then she turns off the key, turns it back on and it runs a little bit a stops. The green light stays steady until it stops then blinks..any help?
Ztarg is the Medline Industries approved service and parts distributor for the Strider and Gemini Scooters.
Their contact information can be found on their website www.striderscooterservice.com
Dec 15, 2008 | Electric Strider Midi 4 Wheel Mobility...
Health & Beauty Logo
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
ray gallant
Are you a Health and Beauty Expert? Answer questions, earn points and help others
