Question about Manitowoc Kitchen Appliances - Others
The code is the shape of a orange triangle with a exclamation point ( !) in the middle of the triangle.
Possible un defrost cycle
Posted on Jun 02, 2019
Testimonial: "Ok , I will check to see ?"
SOURCE: ice cube cycle time very high
i suspect a defective liquid line or pump down seleonid coil. just make sure you hear the "click" when it starts up if not the selenoid coils could be defective. also verify that the condenser fan is running,because if not you are short-cycling on high head pressure. please contact if you need any additional info
Posted on Jun 13, 2008
SOURCE: How Do I maintenance a manitowoc series 150 ice machine
find the filter remove clean with water, coils should be shiney. This should fix the problem
Posted on Jul 23, 2010
SOURCE: i have a model qd0452a manitowoc and it will not
Very unusual for one of these to not stop. There is a magnetic proximity switch located on the bottom right side of the water curtain that serves to both cancel a harvest/drop and to shut the unit down on a full bin. When a drop occurs the control board sees a open and then close of the switch and restarts a freeze mode. If the ice drops and the bin is full the curtain is blocked by the ice behind it from closing again and the unit shuts down on a full bin indication. If the curtain does not open and close after 3 hours it would lock the unit out. Therefore I assume that the switch and the board are working. Most likely you either have the unit on a non-Manitowoc bin or are missing a deflector plate in the Manitowoc bin and the ice is falling out of a service door.
Posted on Dec 11, 2010
SOURCE: My Manitowoc Ice machine is making ice slowly and
You're bridge thickness is set to high, lower the bridge on the sensor located when you open the front door behind the water curtain on the top. If the sensor is scaled badly replace it.
Posted on Feb 14, 2011
Nov 26, 2014 | Refrigerators
May 27, 2014 | Manitowoc Ice IY-0504A 161 Cube-Style Ice...
Mar 04, 2014 | Manitowoc ID0452A-161 Dice Cube Air Cooled...
Nov 20, 2013 | Manitowoc QD0273W-161 Dice Cube Water...
Sep 06, 2012 | Refrigerators
Oct 06, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Sep 18, 2011 | Manitowoc Heating & Cooling
Nov 17, 2010 | Manitowoc SY0454A S Series Ice Maker...
Jul 24, 2009 | Maytag MFI2568AE Side by Side French Door...
346 people viewed this question
