Onida hts 1000 volume buttons not working vol leds not working
Posted by Jayarajankb Balan on
3 Related Answers
SOURCE: the volume button has a faint bluish pink light, vol not workin
there is ribbon cable that may be loose or replaced
Posted on Jul 19, 2009
Anonymous
SOURCE: DNX7120 issue with VOL increase
I had the same issue. You can use the on screen volume buttons on screen to stop issue and don't use the physical buttons anymore. Watch out about a month after the volume problem started all physical buttons on my DXN7120 stopped working. There are a few reports of this online, I have not found a fix yet.
Posted on Jan 08, 2011
eagle338
eagle338
  • 4889 Answers
SOURCE: off/on,vol.up/dn,audio,video,mute buttons on
Since the buttons are fine it is definitely a problem with the main board(digital main). The problem is associated with logic control circuitry malfunction which is causing it to send commands to the microprocessor at will. The part is a large board, which is located near the board with all the inputs and has lots of ICs including the microprocessor. I have found a part but just make sure that the part number(934C265001) matches with the one in your set(the number will be printed on the board) before you order. It costs 357$ but they will return you 208$ if you ship them you faulty board, which works out to 148$
http://www.tvserviceparts.com/934C265001.html
Posted on Jul 28, 2011
Onida hts-1000 remote model no
I want remote control onida HTC 1000.pls. My contact no.9978945063
Jan 23, 2013 | One For All URC-3445 Remote Control
I have Onida TV Model 21 inch , I accidentally enable the features of volume lock, hotel mode and channel lock and I cannot reset the same. Due to this, I cannot increase volume of telivision
MIGHT WORK IF YOU:
Turn off tv with remote, that is standby, then turn off tv with switch or unplug from wall. Wait a few minutes until led lights go off on tv. plug tv back in. try pushing vt on remote and power button on tv at same time.
If this doesn't work try contacting a local retailer, they always have a list of codes for their salesmen.
Jan 07, 2012 | Televison & Video
I have 17'' onida color tv with model no: 20XS Dlx, which got locked by mistake.... now it is asking for the password.... how to resolve this ?.
YOU ENTER 1147 OR 5963 OR PRESS ZOOM BUTON AND VOL- KEY BOTH
Either try 1147 or 5963. Or try pushing both the zoom and Volume down key at same time.
Jul 25, 2011 | Televison & Video
DNX7120 issue with VOL increase button. When this button is pressed once, the volume skyrockets to max, VOL decrease button does not work right away to lower the volume, nor does the ATT button. Unit...
Dec 15, 2010 | Kenwood DNX7120 Car GPS Receiver
How to increase volume
To change the ringer volume: while the phone is on the hook press the Vol + or Vol - button. The phone rings according to the current setting. Tap the Vol + or Vol - button to adjust the volume one setting at a time. The phone stores the setting after the last button press.
To change the speakerphone, handset, and headset volume: while the phone is in use in the desired mode, press the Vol + or Vol - button. The phone stores the setting after the last button press.
The above is from pages 14-15 of the manual at
http://www.rca4business.com/products/pc/pdf/instruction-book/25424RE1.pdf
Jun 11, 2010 | General Electric RCA-25424RE1 4-Line...
Describe your Panasonic PT-60LC14 60 in. Rear Projection HDTV Television Problem: Need to reset timer light--how does one do that?? We got the new lamp installed but it keeps blocking the screen telling...
Hold VOL - on the TV then aim the remote at the TV (watch so that your arm doesn't block the remote signal and press PIP or the SPLIT button. Do this together for at least 5 second. I hope this helps.
Mar 18, 2010 | Panasonic PT-60LC14 60" Rear Projection...
My TV Volume Locked to Number 20
Go to sound menu...Press down arrow to select VOLUME LOCK...press zoom & Vol- buttons together.
Jan 27, 2009 | Televison & Video
No Sound
1) First check the mute.
2) Make sure there aren’t headphones plugged in, that will disable the speakers.
3) Check the audio setup
4) Check your Volume lock
Changing Volume Lock
The remote comes preset to allow independent volume control of each selected device (Global Volume Unlock).
However, you may change the Volume Lock setting to Global Volume Lock so that one device’s volume will
control volume in all other modes. After that, you can perform Individual Volume Unlock on a selected device to
set its volume control for independent operation or Global Volume Unlock to remove all volume locking.
Locking Volume Control to One Mode (Global Volume Lock)
1. Press and hold SET until the red LED blinks twice; then release.
2. Enter 9-9-3 and then press the mode key for the device you want to control volume (for example, TV).
The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected device (for example,
TV) will control the volume regardless of the current mode.
Unlocking All Volume Control (Restoring Global Unlock)
2. Enter 9-9-3 and then press VOL+. The LED blinks four times. Volume is now
independently controlled for all programmed devices.
Unlocking a Single Device’s Volume Control
1. Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
2. Press and hold SET until the red LED blinks twice; then release.
3. Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
independently controlled for the selected
Mar 15, 2008 | Polaroid FLM-2632 Television
I have a philips Matchline tv (29pt6361/79r) the tv works fine except it automatically turns the volume down without any buttons on the remote or tv being pushed
well depends on how far it turns the volume down as to what the cause is and if the volume bar on screen display comes on when the vol. goes down. if it just goes down a little you probably have the "smart sound" setting turned on in the audio menu turn it off and see if prob. goes away. if the vol. bar comes on the screen whenever the vol. goes down the you most likely have a bad button on your front panel and it doesn't have to be the vol. down button. it you think it is the button it would need solder work to be changed most likely shop job.
Mar 08, 2008 | Televison & Video
27 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
