SOURCE: My keys (HP-540) for contrast,brightness are not
Are you holding down your function key while pressing those corresponding keys?
You should see a key labeled "Fn" "F" or similar. It may also be labeled Mode.
It is generally "Fn" and blue.
Press and hold this key, and then press the F7 or F8 key repeatedly to adjust.
Hope this helps
Let us know
SOURCE: screen went upsde down
What do you mean the screen went upside down? Have you moved the Taskbar to the top? If so, right-click on Taskbar, make sure it is not locked(not ticked at Lock the taskbar), then left click on an empty space of the taskbar holding down the mouse button and drag the taskbar around the edges to where you want it.
[1] Press the MENU button to open the main
On Screen Display (OSD) menu.
[2] Press the [
three times until the Parental Control
menu opens.
[3] Press the [Down] button on the remote control
to highlight Parental Lock Enable. The
"Key-In Access Code" window opens.
[4] Use the number pad to type the default
password (0000) or whatever password
you have changed it to previously, then
press OK.
[5] Press the [Down] button on the remote control
to highlight Access Code Edit.
[6] Press the [=>] button on the remote control
to enter the submenu. You will need to
use the number pad to type default (or
what you changed to previously) password
first
[7] Use the number pad to type the new
password.
[8] Confirm the new password by retyping it.
[9] Press EXIT button on the remote control immediately to exit the OSD menu
In Konica Minolta bizhub 210,162,211,163,182, error code
"cof32" means "Automatic toner density control abnormality.
To remove this code or you want to get rid of this problem,
simply call your technical service representative to solve this problem.
If you want to remove this code by yourself then please
perform these actions attentively.
1-Turn the machine ON.
2-Press "Utility" button on front panel.
3-Now press these buttons "stop+0+0+stop+0+1" it means press
stop button, then press 0,again 0, then again press stop button, then press 0, and
1.
4-service mode will appear on LCD screen.
5-Now with the help of arrow keys go to the 2nd
option which is "ADJUST"
6-Now press "YES" button.
7-Again by pressing the down side arrow key go the option
which is "ATDC ADJUST".
8-Press YES button.
9-Now increase the value, for example if the value is 145, you have to enter 155 or
160.enter the value with numerical key pad buttons.
10-After entering the new value press "YES" button.
11-Restart the machine.
