Ive tried to reset using the online trick with tunring the knob clockwise and anti-clockwise but it hasn't worked.
SOURCE: Our 2000 VW Cabrio wont
get a can of WD40 and coat everything with it... don't be that sparse with it. keep in mind oil does not conduct electricity but it will repel the water.
Robert
SOURCE: Electric mirrors not working
Try check the fuses. If they are ok, then try checking the switch panel, it might have accumulated some water or liquid that you used which later caused some short circuit or corroded the terminals, Meaning there is no complete circuit for the mirrors.
SOURCE: 2002 eclipse rs with wet floor
Pull up the carpet and see if the rubber plug in the bottom of the floor pan is in their or in their tightly (should not be loose) unless it is coming up higher from the firewall
SOURCE: i just replaced a rear wheel bearing. Now the ABS
Either drive it until it has gone thru several drive cycles,could take days, or use a code reader or scanner,and see if that works
SOURCE: right floor wet but not
It sounds like yourdrain hole for your ac evaporator is clogged and needs to be unclogged. This can be done by taking it to a shop and have them blow out the drain hole with a air gun. They may not even charge you if so it should not be much.
