Question about Generac Electrical Supplies
Can Code 1902 for a Generac 8KW be fixed by the owner?
Posted by Shirley Allen on
Carl Rock
  • Generac Master
  • 2,533 Answers
If you have some fundamental electrical training/experience.
Undervoltage 1902
ALARM
Fault is displayed when both zero crosses are missing from the controller's input for 1.5 seconds or more. Could be a faulty excitation winding, zero cross circuit, loose wiring, or field boost hardware problem. Same applies here, v1.12 or later firmware should be installed.
Posted on Jun 02, 2019
STEVE SPAM REMOVER
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Generac Master
  • 36,283 Answers
  • 2 more comments
  • Gregg Mahin
    Gregg Mahin Jun 01, 2019
    Why don't you meet me the unofficial experts [email protected]
  • STEVE SPAM REMOVER Jun 01, 2019
    because i couldn't be bothered to greg.
  • Gregg Mahin
    There is a reason I do what I do if you do not want to hear it then quit your complaining
    not a complaint at all just stating the facts man. do what ya gotta do. there is also a reason i do what i do.
Generator hard to start and sputters like its missing
About 15,000 results (0.73 seconds) Search Results
    2 - Generac : Questions, Answers, How To, FAQs, Tips ...
    answers.generac.com/answers/1506-en_us/searchquestions.htm?...
    Can I run an 8kw standby generator on a 100 lb propane tank? 2 answers ... What am I getting for the extra cost of the Guardian unit? ... The engine starts hard and runs rough. 1. Air ... On auto start, unit sputters and I smell gas. ... Does the gas and electrical feed into the unit from the back as previous air cooled units?
    2 - Generac Questions and Answers
    answers.generac.com/answers/1506.../generac.../questions.htm?...
    On auto start, unit sputters and I smell gas. .... The 20kW automatic standby generator has the option to delay start up during an ... This is for a guardian 20kw. ....has been designed to make the battery installation and removal so difficult? ... The air cooled generators are designed to allow for the smallest footprint while still ...
    3 - Generac Questions and Answers
    Generac's Guardian Series 17kw automatic standby generator does not come with a.... The automatic response features of our air-cooled units initiates the unit's startup,.... This week I tried the same and it tries to start but just sputters and fails until .... A C delayed start still chocks 17kw generator would a hard start kit help?
    On auto start, unit sputters and I smell gas. On manual start ...
Feb 08, 2016 | Generac Guardian Air-Cooled Standby...
I have a natural gas generac 8kw it was running fine now it will not run found that out after the last power outage pull the plug looks good found that it will not spark at the plug
How old is it???? Does it have a read out that tells you what's wrong?????When is the last time you did a maintaince tune up on it???? Mine is fueled by propane and I changed the oil and plugs and it's been fine since....Sometimes it's the starter/ignition..I would do a complete tuneup first, then clear codes, then try starting it up manually....If that works put it back on auto..Good Luck
Mar 01, 2015 | Generac 13,000 Watt / 13,000 Watt Home...
How to reset default due to over cranking and not starting due to cold
to reset any shutdown code on units 2010 and newer, switch generator to 'off', press 'enter'. this will clear the code, then you can attempt to start by switching to manual.
Feb 20, 2015 | Generac Guardian 8kw Standby Generator
How to replace battery in a generac standby 8kw generator
Switch generator to off. Remove 7.5A fuse. Disconnect Negative (-) battery terminal first and then Positive terminal (+). slide battery out the front (may be a tight fit) and install the new battery reversing removal steps. Connect (+) first and (-) last. Reinstall 7.5A fuse and switch to manual to start and test run.
Sep 06, 2013 | Generac Guardian 8kw Standby Generator
Guardian generac 10kw model 5502 does not output correct voltage
the instructions says the voltage regulator is automatic/digital. when you check the voltage is there any load on the generator? if applying load to the generator doesn't help, you can manually change the motor speed where the governor connects to the carborator, but it may change the frequency, but the regulator may fix it
Apr 12, 2009 | Guardian Electrical Supplies
Electrical Supplies Logo
186 people viewed this question
Top Generac Electrical Supplies Experts
Sheldon Dedek
JOHN LAPIER
Bill Johnson
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
