Question about Fisher and Paykel Washing Machines
Fisher and Paykel Front Load Washer - Error 37, can't unlock door to drain machine.
Hi, my Fisher and Paykel front load washer has error code 37 - I know I probably need to clear the pump, but I can't drain the water as the door is locked the machine is full of water. How do I unlock the door to manually drain the water? I have tried turning it off, tried every dial and button, nothing. Thank you!
Posted by Olivia Breed on
Paula Hamilton
  • 862 Answers
Hi, you should beable to put a thin knife into the slot on the little door flap at the front on the right side and gently pull the door flap down, then unscrew the plug and the water will drain out, put a larg try underneath to catch the water, best to undo the plug enougth so that when the tray is full you can tighten the plug why you empty the tray, all the best.
Posted on Jun 01, 2019
5 Related Answers
Anonymous
SOURCE: Door won't open on Samsung washer
This has happened to me twice. Both times I found the drain pump seized up with
1st time) The right rim from a pair of reading glasses
2nd time) A plastic toothpick
Both times the object was in the discharge port of the pump. You can see this by lifting the check valve with the pump removed. Removing the pump is simple. Unplug the washer. You have to remove the drain line from where its attached to the rear of the machine (one screw) to remove the rear access panel which slides into upper and lower slots. You will see the pump with an inlet and discharge line attached. The lines have simple squeeze clamps. When you remove the lines, you will drain the wash basin so have towels and a squeegie handy. Remove both lines and wait until the basin drains. When it stops draining remove the pumps electrical connector by squeezing the release catch on it while pulling it. The connector can only go on one way. Remove the 3 hold-down bolts on the pump baseplate. Remove the pump and lift open the discharge check valve and you'll find something there I guarantee it. Remove with needle nose pliers and re-assemble in reverse order.
This is actually a good design because the computer protects the pump by sensing a higher than normal current draw when foreign debris gets jammed in it. It will trigger the ND (No Drain) code and sometimes lock the door. Always check this first before you call the expensive repair man. If its not a jammed pump it will most likely be the control panel/processor. Good luck and always clean out pockets before loading the washer to prevent this,
Posted on Feb 14, 2009
Anonymous
  • 56 Answers
SOURCE: GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Posted on Feb 07, 2010
techbuster
INDIRA KUMAR
  • 5081 Answers
SOURCE: Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
Posted on May 21, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: LG front load washer OE error. cleaned filter need
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!
Posted on Sep 18, 2010
luisa_sgro
  • 713 Answers
SOURCE: how do I take apart my fisher & paykel top
Hi just read your posting.Now if you look under the machine to the front right you will see a fan.This is your pump.Turn the fan a few times to loosen it.The fan should turn freely.Put the machine back on its feet and select a spin cycle and push the start button.The machine should start to drain.Please reply on how you got on or if the machine still does not drain or for further assistance.Looking forward to your reply.
Posted on Oct 08, 2010
I have a error code 37 on my [email protected] 8.5 kg front loader I have all my kids clothes for school in there it says door locked how do I get it open and clear code please
Error code 37 means pump blockage error.
3 things:
Drain hose kinked.
A blockage in the pump or hose
Pump is jammed with something
Empty as much water out with a saucepan. Next -Taking the machine outside is well recommended - tilt the machine back onto a chair to get access to the pump. Unplug the wires to the pump and the earth wire. Lift the white lever and rotate the pump to remove. This takes a bit of forcing. The rest of the water will gush out. Check for things such as hairclips or coins etc. Blow down the drain hose to see if there is any blockage. Replace the pump and make sure the white lever CLICKS back into position. Replace wires.
Good luck
Jun 21, 2015 | Fisher and Paykel Washing Machines
Code 37 -
To my knowledge, Error Code 37 on a Fisher & Paykel machine refers to "drain fault" which could either mean that the drain valve will not open or that the drain pump will not run. The easiest user intervention that could be performed is to check for any blockage/clog at the drain filter, drain pipe, drain pump impeller and drain valve.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 16, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and paykal IWL16 washing machine showing fault 37 tub not emptying or spinning when put on spin cycyle
Hi just read your posting.Error code 37 means PUMP BLOCK ERROR.Drain some of the water by hand enough to look under the machine to the front right.Do you see a fan.If you do this is your pump.If you do not see a fan then you have the new style of pump.Please reply on which style of pump you have and I will guide you in rectifying this fault.Looking forward to your reply.
Oct 11, 2010 | Fisher and Paykel IWL12 Top Load Washer
How do I take apart my fisher & paykel top load washer to get to the water pump. I have an error code 37 which means blocked water pump
Oct 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel GWL15 washer stops during wash, beeps, and displays the 3rd, 6th, and 8th lights. The problem began intermittently about a week ago; however, powering off, changing the cycle, and...
Hi just read your posting.Now error code 37 is called pump block error.This means either your drain pump is jammed, or the drain pump is blocked or the pressure switch tube that regulates the water level is kinked or blocked or the motor controller is faulty.Does your machine always drain the water?Please reply and let me know if your machine is draining the water and we can track the fault down.Looking forward to your reply.
Sep 16, 2010 | Fisher Paykel EcoSmart GWL15
I have a #37 code (pump blocked error) on my fisher & paykel ecosmart GWL11 washer. How can i fix this
Hi just read your posting.Now 1st I need to know which type of pump you have on your machine,Please look underneath the machine for me to the front right.You should see a red or black fan.This is your pump.If you do not have a red or black fan attached to your pump then you have the other type with is held in by 2 screws.Please reply and tell me which pump you have and I can guide you throe the removal and cleaning of the pump.Also is your machine draining into the laundry sink or elsewhere?
Jun 26, 2010 | Fisher and Paykel GWL11 Top Load Washer
Top loading intuitive washer says fault code 37
This machine calls this error number for most faults.
So first let us know what stage it stops at.
The most common fault is blockage in the pump.
Remove the power plug, disconnect the 2 water hoses and tilt the machine onto its front.
It is simple to remove and replace. Disconnect the 2 sockets from the pump The pump is held in position by a latch on the left hand side. Depress the latch and twist the pump anti clockwise. Clean out , add a smear of vaseline to the rubber ring.
Reassemble in reverse
Mar 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Too many suds
Most probably a blocked or partially blocked pump.
Sep 18, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
435 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
peter gittos
peter gittos
Marvin
Marvin
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
