Question about Radio Communications
Gme tx 3600 will transmit but will no recieve
Posted by peter gazan on
2 Related Answers
JOHN BABA
  • 1274 Answers
SOURCE: the squelch wont work and it wont recieve or transmit
REPLACE THE FINALS,does it come on?
Posted on Feb 15, 2010
Ryan Gantt
  • 28 Answers
SOURCE: I have a gme tx3220 which will not transmit over a distance but will if a vehicle is next to you it has a gme ae4018 aerial
Check the coax, make sure it's ok and or have a SWR meter put on it
Posted on Jan 03, 2015
No transmit tx light does not go to red when keyed up. redio was pluged in backwards. has recieve.
its very easy to blow the transmit transistor circuit if shorted
https://www.cobra.com/sites/default/files/manuals/29LTDCLA.pdf
May 10, 2015 | Cobra 29 LTD CB Radio
My digitech dc-1005 will sinc ok ,but one will talk and recieve one way but not the other way, has anyone ant ideas on what could be wrong with them,im thinking the rx or tx on one of them may be ********.
There are 2 oscillator circuits in each unit- one for transmit and one for recieve. It is likely the recieving section of the one that does not recieve the other is slightly out of tune.
Jan 25, 2012 | Radio Communications
3 light on last two blink
The first light, I assume is on constantly, is power/connection, and the two that blink will be Rx and Tx, Rx = recieving data sream, Tx = sending data stream, even if you think that nothing is being transmitted, "static" is sent/recieved to maintain your connection.
Jun 11, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
TK 380 not transmiting
Its most likely was programmed with a rx but no tx. Meaning it can recieve but not transmit, you can fix this with the programing software.
Jan 25, 2009 | Kenwood KNB-17AM, TK-280, TK-290, TK-380,...
Transmitting
read the radio on the computer and see if the TX is enabled.
Also the PA could be faulty
May 02, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
SL55 Not Transmitting/Recieving
the two radios are on different CTCSS Tones
Feb 01, 2008 | Maxon Radio SL55, SP130, SP140, SP150...
Does not transmit
Model #? Name?
black box? make sure the tx rx are reverced on both ends.
Jun 21, 2007 | Black Box (IC109A-R3) Transceiver
Radio Communications Logo
135 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Radio Communication Expert? Answer questions, earn points and help others
