Question about Cooktops
Sorry posted in cars. DCS cooktop regulator failed. Can't unscrew connection between regulator and cooktop distribution tube. Has beige fill. Any suggestions?
Posted by Steve McAfee on
  • Steve McAfee
    Steve McAfee Jun 01, 2019
    Basically I'm just struggling to unscrew the regulator from the square gas tube which is part of the cooktop. It's a standard Harper-Wyman regulator for 10" W.C. LP. There is light brown gunk on the exposed threads which is probably holding it tight. The regulator is garbage and I have a replacement but I can't seem to get it to budge.
  • Steve McAfee
    Steve McAfee Jun 04, 2019
    I got it off with two 24" wrenches.
1 Related Answer
dcshelper
  • 7 Answers
SOURCE: replace dcs gas cooktop re-ignition module
donho1,
most likely the problem is the switch places onto the shaft of the valve. to replace the switch, you would need to remove the burner cap and port rings. you will see a large brass nut that needs to be removed on all 4 or 5 burners. next you would need to remove the nut in the center of the simmer port ring which is also the venturi for the main burner. you must be careful when removing this nut as they have a tendancy to lock onto the jet holder and could be hard to remove (don't strip or break the venturi or holder).....after you remove those nuts, the burners and top can be removed (watch the igniter wires). you can remove the switch by removing the retainer clip that holds the switch onto the valvestem.
Posted on May 28, 2009
While trying to remove the top of the cooktop, I seem to have stripped the threads of the copper tube securing one of the burners. How can I remove the top of the cooktop?
Not sure of your situation but if you can get a flat screwdriver and wedge it under what you are trying to unscrew and pry up as you are unscrewing it you may get it.
Feb 10, 2016 | Cooktops
DCS 36 in. CS-366 LP Cooktop ignition
in that burner something is short check it out
Dec 09, 2007 | DCS 36 in. CP-366 Gas Cooktop
DCS Cooktop CTD-365 one burner won't ignite/no spark or ticking. I cleaned ignitor.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Aug 11, 2010 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
How do I remove knobs for burners to clean them?
To remove the knobs from the cooktop you just pull them off. They are only presser fitted on a post.
Jul 30, 2010 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
Electronic igniters will not turn off when the gas burner lites. all four igniters run untill you turn off the nob or unplug the unit
I'm dealing with this same problem. This cooktop has a dedicated simmer burner which is the only thing going on the lowest setting. This simmer burner seems to be how the igniter senses that it can stop. If it doesn't light, the igniter keeps clicking. Usually cleaning the burner will solve this. You may need to unscrew the nut holding the lower piece of the burner in place in order to clean it up.
Apr 17, 2010 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
The igniters will not stop sparking on my dcs cooktop when I turn the burners on. This happens with all burners.
Because this is happening on all burners, i would say you have a faulty ground to the ignition module.
Dec 19, 2009 | DCS 36 in. CP-366 Gas Cooktop
Where can I get a igniter for the DCS CTD-365n cooktop.
i couls not find this model / reck your model # and need the brand / this will help . sorry mm
Dec 02, 2009 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
Good advise on removing the knob. My problem is that the Valve stem has excessive play in it. How do I replace valve stem.
Hi, the valve stem on a gas stove is on a manifold assembly under the top. If I am correct in remembering, the burner valve unscrews to replace them. If so, take it with you along with all of the numbers,M#, S #, and so on. Best of Luck,
Shastalaker7
Nov 23, 2009 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
Hello posted this question but family getting antsy without a cooktop. I am installing a 36 inch GE Profile gas cooktop, jgp970, along with a Frigidaire downdraft vent, pl36DD. The gas inlet pipe on the...
the reason for the fitting instruction for the regulator to be connected directly is that flex hoses deteriorate and allow a dangerous situation
AS gas is not in the diy domain I recommend that you get in an accredited gas fitter who will make a solid pipe to allow the fitment of the regulator away from the motor
While he is there he can adjust the regulator to get it all working correctly
Mar 13, 2017 | GE 36 in.JGP970 Gas Cooktop
DCS range igniter won't stop
Hey all ... I just had a repairman fix my DCS cooktop that was doing the same thing ... ignitor problem. He replaced it and it's good as new. (Cleaning also did NOT work for me.) It cost me $216 for the repair. If you can find the part, it's pretty easy to replace. Just take off the front knobs (be careful as there is a 'ring' inside the neck of the knob) and unscrew the front. You will need a special screwdriver - looks like a star - but just snip the plastic straps holding the original ignitor in place and put the new one on the same way as the old one. You should be good as new. REMEMBER TO TURN OFF THE BREAKER!!! I can't imagine it would take more than an hour (tops) 'cause it looked pretty easy.
Sep 01, 2008 | Cooktops
Cooktops Logo
128 people viewed this question
Top Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
