Question about The Health & Beauty
Change kg to lbs on walgreen scale
I have a Walgreen Digital Glass with Body Analysis scale and I can't figure out how to change it to display pounds instead of kilograms. I can't find the manual either
4 Related Answers
Anonymous
SOURCE: How do I change the scale to read pounds instead
Turn over the scale, on the bottom, there should be a little black switch that you can use to select between lbs and kilograms.
Posted on Jan 03, 2010
Anonymous
SOURCE: can not change from Kg to Lbs
Flip over the scale, on the back there is a black button, slide it to pounds.
Posted on Apr 05, 2010
Anonymous
  • 33 Answers
SOURCE: I can't figure out how
depending on the make and model, there may be a switch on the underside of the scale, or inside the battery compartment.
Posted on Aug 02, 2010
joeguest2
Joe2
  • 2080 Answers
SOURCE: I lost my instruction manual
Look on the bottom of the scale for a sliding switch to alternate between Kg and lbs.
If you do not see one then remove the little cover and check inside the battery compartment for it.
Good luck.
Comment back here and rate with 4 Thumbs up if this was at all helpful.
Thank you.
Posted on Feb 23, 2011
4helpful
How to change kgs to lb
There's a small "unit" button on the bottom/back of the scale. Press this until it goes back to lbs. It should cycle between kg, stones, and lbs. If that doesn't seem to be working, press and hold for 4 seconds or more. The screen will flash "reset" and it will have gone back to default, factory settings.
1helpful
On my "Ideaworks" wireless electronic display
After playing with the remote on this scale for about 30 minutes, I finally found out how to change this display from kg to pounds or stones. Since this scale doesn't come with an instruction manual, I know a lot of people are totally lost. OK, first click the user button once, so that the weight and goal weight show. Then hold down the clock/set button. After a few seconds the kg on the screen will start blinking. Then use your arrow buttons to switch to stones, then to pounds. The lb will show at the top of the display above where the kg was. You can also set your goal weight by pressing the set button and scanning through after setting the lbs setting. Hope this helps!
5helpful
Change scale from kg to lbs
Ok i Just figured it out my self with no manual. When you put new batteries in your scales the unit will be shut off. Press and hold the select button for 5 seconds and then it will show LBS or KG and you will be able to change your weight at that time. Hope this helps.
3helpful
Jobar international JB5413 large cap. scale It shows in kg i want to change it to pounds.
press WT then press SET for 3 secs
then use up/down arrows to change between kg lb and st
when selected press SET again
13helpful
2answers
Can not change from Kg to Lbs
9helpful
2answers
I have a Producx digital scale and I can set the person, age, and heights but cannot change to pounds.
There is a small switch on the back of mine that says "lbs/kg/stone", and you slide the switch accordingly.
2answers
Need instructions on how to reset to show weight
how do I change scale from kg to pounds?
78helpful
3answers
Somehow my tanita ultimate scale has been switched from pounds to stones. How can I get it back to pounds?
Q: Why does "st-lb" or "kg" appear when taking a measurement?
A: The unit's "Weight Mode" has been set to measure your weight in units of stone-pounds (st-lb) or kilograms (kg). Tanita's Body Fat Monitors and the UltimateScales can measure weight in three different modes: lb (pounds), kg (kilograms) or st-lb (British stone-pounds). To change the setting, first find out which model you have (it should be written just above or below the display screen of the unit).
Method 1
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
64helpful
3answers
Scales show weight in kg. How to get them to show lbs.
24helpful
2answers
Tanita, the Ultimate Scale
The scale may have instructions on the bottom of the scale. (Example for the Tanita: The Ultimate Scale w/ the body fat analysis). The instructions on the back state the following steps: Step 1: press both the "Set" and the triangle buttons. Step 2: press the "triangle" button until you select the appropriate weight measurement (a) kilogram, (b) stone lbs or (c) lbs. Step 3: press the set button.
Open Questions:
Health & Beauty Logo
Top The Health & Beauty Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Paul Carew
Vernon Taylor
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
