Question about Measuring Tools & Sensors
I have a new DM 4100 by Sperry and can't get the back open to change the battery....It is stuck or I don't know what I'm doing.. Jim
Posted by Jim Payne on
rwkemper
  • 4 Answers
1. Disconnect the test leads from any energized circuit and then from the instrument.
2. Turn the range switch to the "OFF" position
3. Slide off the back case battery cover.
4. Remove the battery from the compartment and unsnap the battery connector.
5. Replace the battery with a 9V transistor type battery (NEDA # 1604), For maximum battery life, alkaline cells are recommended.
6. Reverse the above procedure to complete replacement.
Posted on Jun 15, 2019
4 Related Answers
bunnydawg
Roberta Smith
  • 5158 Answers
SOURCE: checking batteries AA D cel with a sperry DM 350A digital multimeter
dc .... no lower then the voltage range of the highest voltage of the battery.
Posted on Sep 14, 2008
Bruce Foote
  • 33 Answers
I assume a "DM-350a" is some kind of a digital multimeter. I Googled and found it might be a "A.W. Sperry DM350A 5 Function 17 Range Digital Multimeter" and looking at the ranges available on that meter, you can't really thest the battery "under load" the only reasonable way to test small batteries. the DC current only goes up to 200 milli amperes. A "C" or "D" size flashlight battery puts out 1 to 4 amps depending on conditions. That's 5 to 20 times the current readable by that meter. The volts on one of those batteries is probably 1.6 volts to 1.3 volts etc. If you live in the United States, I'd say go to Radio Shack and spend $5 to $15 and buy a battery tester like "Enercell Analog 9-Range Battery Checker, $14.99, Model 22-156, catalog # 22-156"
Then you and anyone in your family can read the instructions and test 8 or 9 different type batteries. Battery types: 1.5V button-cells, "AAA"/"N"/"AA"/"C"/"D", 6V, 9V, 12V, 15V and 22.5V..
This is not supposed to be an advertizement, and I have no interest in RadioShack,... but it's supposed to be instructional.
Small price, Good instruction to anyone who can read, and if anyone forgets, they can re-read. Testing a lot of batteries in a sitting goes very fast with these.
Differently, with the sperry, or any voltmeter, you'd have to select a resistor small enough to draw the current, and large enough not to overheat or burn, connect it and measure the loaded voltage drop, compare the voltage and current of the loaded battery, and compare it to that of a new battery, and a battery you might consider too weak for your application.. Voltage equals amps times resistance, and power equals amps squared times resistance... Really, buy a battery tester.
Regards --- GooseBay_Camper
Posted on Sep 28, 2009
Anonymous
SOURCE: Does the Sperry DM-350A test
yes. But you have to change the LEADS down below. One must connect into the Omega connection at the bottom (looks like an upside down horseshoe). And the meter setting is where the arrow (?) symbol is. Touch the two leads together and it should "zero out". Now you're ready to check continuity.
Posted on Dec 11, 2010
Testimonial: "That was helpful. Thanks."
Bruce
  • 311 Answers
SOURCE: Changed battery on Sperry DM-5300 and now it will not power up
Try it again, with a new, tested battery.
You likely installed a "dud" (or put it in backwards?)
Posted on Jan 23, 2015
Jan 23, 2015 | Televison & Video
Replace battery on sperry dm6400 multimeter
remove battery door and replace 9V battery
detailed explanation bellow
http://www.testequipmentdepot.com/sperry-instruments/pdf/dm6400.pdf
Apr 19, 2014 | Sperry Instruments DM6450 64 Series...
My brand new cam nikon coolpix S 4100 got stuck while i was editin a photo...battery is full, unable to switch the cam off.
Pull the battery, try again, if it continues to fault I would take it back and get a replacement.
Oct 11, 2011 | Nikon Coolpix 4100 Digital Camera
Does the Sperry DM-350A test for continuity? I can't seem to find a setting that works.
Dec 03, 2010 | Measuring Tools & Sensors
Checking batteries
Sep 26, 2009 | Sperry Instruments HST401 Voltage...
Checking batteries AA D cel with a sperry DM 350A digital multimeter
Sep 06, 2008 | Measuring Tools & Sensors
Change keyless entry passcode for chamberlain model 4100 door opener
You have to press a Yellow/Purple button on the back of the garage door opener unit.
It is the LEARN button. Then enter a new four digit code into the keypad and press the enter button.
The unit should click and the lights should flash. This acknowledges it has learned the new code.
Aug 14, 2008 | Sears Craftsman LiftMaster Chamberlain...
Brother 4100 multifunction LASER
There is a door open in the back. Close it.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Sep 07, 2006 | Brother IntelliFAX 4100 Laser Fax
Measuring Tools & Sensors Logo
142 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
