How about.digital research dr-1000 sub woofer? thanks hopefully using dish remote 103602
Posted by scott campbell on
5 Related Answers
Michael Borelli
  • 979 Answers
SOURCE: Eltax DR-110 Sub-woofer issue
Where have you connected the sub's leads?
Posted on Feb 29, 2008
Anonymous
SOURCE: I have a teac AG
I have the same-just talked to TEAC last week, if fuses(two 5 amp glass ones inside housing-just remove screws on back after un-plugging 120v power) on the LSR-1008 subwoofer are blown, it may be failed relays. I replaced my fuses, both blew w/in 5 seconds. Called TEAC today, relays are NOT available alone and are solder connected; however, complete new circuit board is plug in, part #APE000515-0001 at $47.69 plus shipping. Verify #s and price with TEAC, but now I must decide if it's important to keep this sub, or if another at around 60$ on Ebay is a better bet. Good luck!
Posted on Apr 16, 2009
Anonymous
  • 124 Answers
SOURCE: Velodyne sub woofer: Series S Model: VA08BVX10
The volume control pot can be replaced.
Any good quality audio shop or electronics repair shop should be able to fix this.
Posted on Nov 21, 2009
Carlos Oliveira
  • 62 Answers
SOURCE: How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Posted on Mar 07, 2010
Anonymous
SOURCE: Panasonic Sub Woofer
I Have the sub woofer SB wa 340, but I need the remote control if posible bussines send me the information 7862873227
Posted on Aug 03, 2010
I have a "Dish" universal
Your post caught my attention, paulobrien1, as I found it interesting! Here are the codes for a Phillips DVD player: 925, 585, 554, 556, and 678. If you have any questions or issues with that, I encourage you to let me know so I can look into it a bit further for you!
Hope that helps!
Aug 21, 2011 | DISH Network IR Remote Control
Steps to set ir 103602 to dish receiver
msg0624
I have provided a link with instructions for programming your remote to your receiver.
Program remote to receiver, step 5:
http://www.dishnetwork.com/SupportSection/remote-setup
Ray Calo
DISH Network
Sep 22, 2010 | DISH Network IR Remote Control
Codes
scorpionjdl6
I have provided a link with instructions on how to program the remote to your Magnavox TV and with the remote codes. I hope this helps.
Ray Calo
DISH Network
Mar 02, 2010 | DISH Network IR Remote Control
Need sharp tv codes
The codes for a Sharp are 526, 585, 591, 605, 606, 607, 608, 628, 629. Thanks for using Fix Ya.
Jun 02, 2009 | DISH Network IR Remote Control
Need Sanyo TV code numbers
These are the codes for Sanyo TV'S for this remote. The newer TV codes are at the end so work in reverse order when inputting these codes. Thanks for using Fix Ya.
542, 589, 590, 591, 592, 609
May 22, 2009 | DISH Network IR Remote Control
Only VCR button lights when I hit power
OKAY IF YOU NEED ASSISTANCE PROGRAMMING THE NEW REMOTE TO THE TV OR RECEIVER LET ME KNOW. THANKS FOR USING FIX YA AND FOR ALL CAPS.
Apr 19, 2009 | DISH Network IR Remote Control
Menu button won't work
The codes that are provided to operate the tv from a Dish remote will not offer full functionality with most TV's. The menu button on the Dish remote even when able to bring up the menu screen on TV's is unable to navigate the menu screen due to the complexity of the TV's set up. The newest receiver that Dish has on the market is the 222k which is a dual tuner/two room HD receiver without DVR that has LEARNING REMOTES that might be able to accomplish the goal you are trying to obtain. I hope this answers your question and remember to keep the original TV remote in a safe place so that you can use other functions on your TV as well. Thanks for using Fix Ya and let me know if I can be of further assistance.
Dec 12, 2008 | DISH Network IR Remote Control
My one for all won't program...
dish network remotes are universal, you can program your receiver, vcr/dvd, telivision and stereo to most remotes. if you need info on this just post again, otherwise i would list your issue under the remote brand
Jun 24, 2008 | DISH Network IR Remote Control
Feb 26, 2008 | Audio Players & Recorders
26 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
