SERIAL NR AN01054 KV SR3AM30A THANK YOU
From 1970 sony made TVs, with that name,
I can not decode this KV model
not even at
https://www.sony.com/electronics/support/televisions-projectors/results?query=NR+AN01054+KV+SR3AM30A+
SOURCE: sony tv picture keeps flashing
You likely have bad solder connections around the tuner area. This model has a history of problems in that area or the tuner itself.
SOURCE: Sony Trinitron KV-1670 TV
go to web site www.serviceinfo.com it is available you will have to download.
SOURCE: Standby indicator light on TV flashes - Sony TV
Please check fisrst that indicator liight (LED) blinks how many times.it could be from 1 to 8 times and the interval would be of three seconds.So, count the led flashes how many times and then tell me i will try my best to find and fix the solution.
Thanks
SOURCE: blinking Sony Trinitron with no picture or sound
you have a drive ic problem. ic 600, r640 and modification needs to be performed. Take to a Sony servicer. Est.$150 parts and labor
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I
have over 10 years experience in electronic tech
support.
I
know this isn't what you want to hear, but the problem you've
described can't be fixed with troubleshooting.
Your TV
will have to be repaired. There is a part that has developed a defect
and needs to be replaced. If you're still in warranty, the TV will be
repaired at no charge to you. The warranty would likely be at least
one year from the date of purchase from the manufacturer. If you
purchased an extended service
plan
they will repair the TV at no charge as well.
If the TV is no
longer in warranty, it will likely cost a minimum of $150 parts and
labor. This is assuming that you only need one circuit
board
or small part. If the problem is more than one of the circuit boards,
the price of repair could go much higher.
I hope I've provided
you useful assistance and that this information allows you to make an
informed decision as to how to proceed from here. Please be sure to
vote on my response. I hope I've earned a good rating from you
today.
Please let me know if I can be of further assistance.
