Hi, Power off the printer. Then open the front cover of the system where you replaced the toner .then press an hold the two switches on the printer and switch on the printer while holding down the push buttons ( switch) then when the switch light stops blinking, release the two buttons and that should reset the printer.
SOURCE: Maintenance kit for Xerox 8500
Contact the company that you purchased the maintenance kit from.
They should have the solution or send you a replacement.
I know of no way to change the Xerox printer to match up with a non Xerox maintenance kit. They would not set the machine up to accept non Xerox products since that voids warranties.
SOURCE: Oki C3300 toner replace, where do I stick the new chip
On the top left hand side of the cartridge, usually where the letter representing the colour of the toner (in your case M for Magenta) appears, there is a small removable section, about 15mm by 20 mm in size. Prise this open with your finger nail or small screwdriver. Remove the old chip and insert the new one in here.
SOURCE: Would you please tell me
enter tech mode by : menu # 1934 menu - nothing else
run downl3210.bat (firmare update)-you can find it in a lot of places wait aprox 1 min
enter tech mode - data setup
SOURCE: How to reset waster toner bottle full Xerox 3535
Here's what I did.
Emptied the waste toner cartridge. Left it out of the machine. Held the microswitch (located to the right of the optical sensors) in the "cartridge in" position with a paperclip. Printed one document. Inserted the waste toner cartridge. Error now gone!
GCC.
SOURCE: please help samsung scx
This is a link to view how to reset: http://www.youtube.com/watch?v=Qzc9JImUcak
This is a link to download firmwares (version 1.13, 1.16, and 1.18_fix) and download software to update firmware files to printer: http://dox.abv.bg/files/listtree
MOST IMPORTANT:
1. Push 8 times button MENU then OK to print a report and view your version of firmware
2. REPLACE FIRMWARE VERSION 1.13 ONLY WITH 1.13_fix
3. REPLACE FIRMWARE VERSION 1.16 ONLY WITH 1.16_fix
4. REPLACE FIRMWARE VERSION 1.18 ONLY WITH 1.18_fix
5. REPLACE FIRMWARE VERSION 1.21 ONLY WITH 1.18_fix
6. DO NOT REPLACE FIRMWARE VERSION 1.23, I DON'T HAVE FIRMWARE VERSION 1.23
IF YOU REPLACE FIRMWARE VERSION WITH WRONG VERSION A "SCANNER ERROR" OCCURS AFTER SEVERAL MONTHS WHICH MEANS YOUR SCANNER MATRIX IS BURNED OUT AND MUST BE REPLACED
GOOD LUCK!.
