Question about Car Audio & Video
My sbs 2..1 370 sub woofar is giving bass but not giveing sound
Posted by sujith on
5 Related Answers
Anonymous
  • 72 Answers
SOURCE: Enclosure type
Sealed box and somewhat large if they are 12's I usually try to get 3 cubic feet overall internal dimensions and generally the inside dimensions will be 13" tall 32" wide and 13"-14" inches deep. with no divider and make sure the box is sealed. Personally I like to phase the speakers backwards. Gives the bass a little more rumble.
Posted on Jan 05, 2007
Anonymous
SOURCE: Logitech Z-2300 speakers
maybe the first step could be checking the subwoofer's fuse.it is located over the power supply connector.
Posted on Jan 22, 2008
Anonymous
SOURCE: Infinity Basslink
Thanks for the reply. I took the sub to Best Buy and had the guy look at it - not surprisingly, I couldn't replicate the problem once I was there. It was working fine at that point and he thought maybe the sub got a little too hot and just shut down on its own. It's been fine since then, so hopefully that was it. Still, for others the voice coil may have blown so good to know that could be it as well.
Posted on Oct 17, 2008
Anonymous
SOURCE: car sound system. only sub is giving off sound. other 4 speakers dont work at all
Could be bad outputs from the back of your head unit or also could be bad rca cables. Make sure the amp is on and powered.
Posted on Mar 10, 2009
Anonymous
  • 6 Answers
SOURCE: creative SBS A 500's woofer, rear right is not giving sound.
A weak conection inside speaker or other conections.
Posted on Aug 20, 2009
What is a sound bar woofer and function
A woofer is a device that producers low frequency bass sounds. Often in a form of Sub Woofer. Bass sounds are not directional. So once set up it will give the rumble and vibration needed to the sound system.
Dec 27, 2016 | Audio Players & Recorders
I have a pair of linn komponent 104 speakers i was wondering if i can add a sub woofer to my amp to give the sound more bass as the speakers dont have a good bass sound
The Linn's should have a good bass, clean & tight but not boomy. Have you got them correctly phased? Red-to-red, Black-to-black? Bass is killed if one speaker is anti-phased.
Nov 11, 2014 | Car Audio & Video
I need to know the demensions for 10 inch subs
almost any 10 will use .75 cubic feet up to 1.25 cu ft. thats about the size of a milk crate give or take. a sealed box will give you the cleanest tightest bass. A ported box will be louder but also larger at the cost of decreased power handling ability and sound quality. If your subs are designed for small enclosures use a sealed box around .75 to 1.00 cu ft.
Jan 30, 2010 | Koiiler XM-6715 Car Subwoofer
Creative SBS A 500's woofer, rear right is not giving sound.
Aug 20, 2009 | Audio Players & Recorders
What enclosure do i need for cerwin vega v-max 124 12" sub
Just get a 12" sub box enclosure for an audio store near you or make a custom box, a larger box supposedly gives you more bass yet at the cost of boot space. I have a type R sub and the box is only as big as it needs to be for the sub to fit and it gives amazing bass.
Aug 04, 2009 | Cerwin Vega V-Max 12 Car Subwoofer
What amplifier should I use for 2 650W Subs?
HI DUDE .. I JUST GIVE suggestions Boss Car Audio D5504 "Diablo Series" 4-Channel Car Amplifier 2200 Watts ITS REALY GOOD FOR SOUND SYSTEM DUDEaaf1faf.jpg
Jun 10, 2009 | Pioneer GM-6300F Car Audio Amplifier
Djust
alot of times its not just the amp that gives you better sounding bass.. A lot has a to do with a few other factors as well.. first off your subwoofer.. the bigger the subwoofer the deeper the bass. Some woofers exturde, or flex differently depending on the quality and structure of the woofer.. 2nd is gonna be the sub box. different size boxes will give your sub diff. depths of bass. ... general idea is the bigger the box deeper the bass. But if your woofer is not supplied enough power a big box is useless.   With that size amp your best bet is too run a single woofer. Probably a 10inch woofer would sound the best.. but it in.75cub inch. sealed box.. should sound great.
Nov 11, 2008 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Bought Logitech z-cinema 2.1 but the subwoofer does not seem to work properly...
The subwoofer features Logitech's eight inch long-throw sub in a bass-reflex enclosure. The sub is capable of throwing out 110W RMS with frequencies down to 35 HZ to give you that deep bass for the earthshaking explosions.You must have problem in the product .the installation might have been not proper ... check it via a sound engineer
Oct 02, 2008 | Computers & Internet
I have a pair of Peavey Impulse 1012 4ohm amp a Peavey XR 696f was not geting enough bass ( use a Yamaha TYROS keyboard & Vocals) so i purchassed a pair of Peavey messanger Pro 15 Sub Cabs 4Ohm cant...
Hi fingers 1
There will be some overlap in bass response that you may need to tune out to tone down the boomy bits. You could tune this out with a 31 band EQ Another approach is to use a crossover or low pass filter to the subs to get some control over your bass frequencies. Another thought, if you're using the rig for stage work, how does it sound out the front. It may be standing waves created by the bass bins, moving them to different monitoring positions may also help.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Jun 18, 2008 | Audio Players & Recorders
Car sound system. only sub is giving off sound. other 4 speakers dont work at all
Dec 13, 2007 | Kicker CompVT CVT654 Car Subwoofer
Car Audio & Video Logo
102 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
