Question about Radio Communications
I HAVE THE Z218 RADIO I HAVE IT PROGRAMMED, I HAVE AUDIO ON THE FM MODE BUT NOT IN THE VHF MODE VOLUME IS ALL THE WAY UP.
Posted by Rick Bev Bousman on
2 Related Answers
Anonymous
SOURCE: how can i control volume of the fm radio, tv, and
ITS SIMPLE YOU GET DECREES VOLUME
Posted on Apr 15, 2010
emissionwiz
Marvin
  • 85239 Answers
SOURCE: My radio in my 2003 Grand Marquis works perfectly
You have an antenna problem if this is just on FM
Posted on Oct 24, 2010
I'm looking for the manual for a SoundLogic XT AWS-12/2970R Bluetooth splash proof speaker with FM radio. Specifically, I need the instructions for programming stations into the FM radio receiver.
I didn't see a manual online in searches.
It might be able to discover something from questions on the web sites sellling it, or ask your specific question and see if it is answered.
Example:
https://www.homedepot.com/p/SoundLogic-Bluetooth-Shower-Speaker-with-FM-Radio-and-Carabiner-in-Red-AWS-12-2970R/206079715
Quoted from llink above:
How to use FM Radio in this device This question is from Bluetooth Shower Speaker with FM Radio and Carabiner in Black
November 28, 2015
How do I use the FM Radio in this device. The device description says FM Radio but there is no mention of how to use it.
Answer this Question Answers (5)
December 29, 2015
If you push the middle button it will switch from Bluetooth mode to radio. The first time I used mine it immediately searched through all the radio stations it could detect and store that information. Kind of like when you plug in a new TV. Once that scan is done it will play the lowest numbered station, you then use the buttons on the left or right to advance to the station you want. Don't press middle button again or it will go to Bluetooth. Good Luck
December 5, 2015
Turn on the device with the power button and then press and hold the "play/pause" button down until you hear the radio. Press and hold the back and forward button to control the volume and press the back and forward button with a quick release to switch the radio channels.
December 28, 2016
Hold down the play/pause button until the radio turns on. First time you use it, it takes a couple of minutes to program the channels then use arrows keys to go through the programmed channels.
Mar 23, 2018 | The Audio Players & Recorders
I get static and distortion in Stereo mode.
if you are reffering to a radio fm receiver, the issue is the signal strength is too low.so the multiplex transmission cannot be correctly unscrambled.mono reduces the cross channel interference.
use a high gain 12 db or above external vhf antenna to solve this problem
Jul 29, 2014 | NAD 7140 Stereo Receiver With Phono Input
Need to program baofeng uv 5r
That is outside the 140-174 range of the radio. It cannot be programmed in this radio.
Apr 13, 2013 | Dual Uv-5r Baofeng Feq Uhf/vhf Radio Free...
In Thailand Cb radio users must use freq range 245.000 - 249.999 freqs. Do usa Cb's use this freq?
Thailand actually has three "CB" bands, the first is the same as the U.S. / CEPT (EU "European Community) band 26.965 - 27.405 MHz, the second is a 78MHz VHF mid CB band (I think its either 40 or 80 channels with FM mode) and then the 245.0000 - 245.9875 MHz VHF 80 channel band - apparently the law also stipulates that the 78MHz CBs must be yellow colored and the 245MHz CBs must be red colored.
But yeah, 245MHz Thailand VHF CBs are very illegal in the United States.
Jun 24, 2010 | Cobra 19 DX III 40-Channels Base CB Radio
How do you get audio output from gpsmap 640?
Better if u connect it through FM tuner on your car radio
Jun 25, 2010 | Garmin GPSMAP-640 GPS Receiver
Pro-2051 No Receive Audio
try headphones to see if the preamp stage is working, if headphones work then it has to be either the audio amp or speaker. It could also be settings such as being in the am mode instead of fm if it has a key marked mode press that.
Mar 23, 2009 | Radio Shack Pro-2051 Base Scanner
How to find hidden menu on yeasu 857d
Note: The following was taken from a web site as follows:
http://www.kb2ljj.com/data/yaesu/ft-857.htm
WARNING: changing these will reset all the memories.
I want to warn you do not change these values unless you are sure of what you are doing. To get them turn transceiver off. Press and hold the A,B,C keys; while holding them in, press and hold in the [PWR] switch for 1/2 second to turn the tranceiver On. Now let go of all keys. Attention, for menu NO-017. Input voltage 13.8V = 138 to calibre voltmeter.
Press F key to finish.
Function Setting in my radio
============================================================= Adjust-No Function Setting Mode Frequency ============================================================= NO-001 HF1-RXG 118 CW 1.800.00 NO-002 HF2-RXG 91 CW 7.068.19 NO-003 HF3-RXG 133 CW 21.225.13 NO-004 50M-RXG 106 CW 50.000.00 NO-005 VHF-RXG 77 CW 145.437.50 NO-006 UHF-RXG 103 CW 438.900.00 NO-007 SSB-S9 61 CW 21.225.13 NO-008 SSB-FS 54 CW 21.225.13 NO-009 FM-S1 68 FM 145.437.50 NO-010 FM-FS 99 FM 145.437.50 NO-011 DISC-L 50 FM 145.437.50 NO-012 DISC-H 79 FM 145.437.50 NO-013 FM-TH1 100 FM 145.437.50 NO-014 FM-TH2 100 FM 145.437.50 NO-015 FM-TI1 10 FM 145.437.50 NO-016 FM-TI2 10 FM 145.437.50 NO-017 VCC 138 FM 145.437.50 NO-018 HF1-IC 83 CW 1.800.00 NO-019 HF2-IC 80 CW 7.068.19 NO-020 HF3-IC 87 CW 21.225.13 NO-021 50M-IC 84 CW 50.000.00 NO-022 VHF-IC 72 CW 145.437.50 NO-023 UHF-IC 74 CW 438.900.00 NO-024 HF1-PO-MAX 165 CW 1.800.00 NO-025 HF1-PO-MID2 105 CW 1.800.00 NO-026 HF1-PO-MID1 31 CW 1.800.00 NO-027 HF1-PO-MIN 13 CW 1.800.00 NO-028 HF2-PO-MAX 159 CW 7.068.19 NO-029 HF2-PO-MID2 102 CW 7.068.19 NO-030 HF2-PO-MID1 29 CW 7.068.19 NO-031 HF2-PO-MIN 11 CW 7.068.19 NO-032 HF3-PO-MAX 158 CW 21.225.13 NO-033 HF3-PO-MID2 101 CW 21.225.13 NO-034 HF3-PO-MID1 29 CW 21.225.13 NO-035 HF3-PO-MIN 11 CW 21.225.13 NO-036 50M-PO-MAX 145 CW 50.000.00 NO-037 50M-PO-MID2 92 CW 50.000.00 NO-038 50M-PO-MID1 47 CW 50.000.00 NO-039 50M-PO-MIN 8 CW 50.000.00 NO-040 VHF-PO-MAX 87 CW 145.437.50 NO-041 VHF-PO-MID 43 CW 145.437.50 NO-042 VHF-PO-MIN 7 CW 145.437.50 NO-043 UHF-PO-MAX 112 CW 438.900.00 NO-044 UHF-PO-MIN 16 CW 438.900.00 NO-045 HF1-TXG 48 USB 1.800.00 NO-046 HF2-TXG 38 USB 7.068.19 NO-047 HF3-TXG 43 USB 21.225.13 NO-048 50M-TXG 40 USB 50.000.00 NO-049 VHF-TXG 47 USB 145.437.50 NO-050 UHF-TXG 49 USB 438.900.00 NO-051 ALC1-M 203 USB 21.225.13 NO-052 ALC-M 85 USB 21.225.13 NO-053 HF1-REV-ALC 61 CW 1.800.00 NO-054 HF2-REV-ALC 56 CW 7.068.19 NO-055 HF3-REV-ALC 50 CW 21.225.13 NO-056 50M-REV-ALC 47 CW 50.000.00 NO-057 VHF-REV-ALC 62 CW 145.437.50 NO-058 UHF-REV-ALC 57 CW 438.900.00 NO-059 CW-CAR-LEVEL 144 CW 21.225.13 NO-060 AM-CAR-LEVEL 125 AM 21.225.13 NO-061 DEV-W 216 FM 145.437.50 NO-062 DEV-N 110 FM 145.437.50 NO-063 MOD-MTR 200 FM 145.437.50 NO-064 DTMF-DEV 10 FM 145.437.50 NO-065 CTCSS-DEV 233 FM 145.437.50 NO-066 DCS-DEV 168 FM 145.437.50 NO-067 LSB-CAR-POINT -7 LSB 21.225.13 NO-068 USB-CAR-POINT +5 USB 21.225.13 NO-069 VSWR2 at 10W 17 CW 14.257.90 NO-070 VSWR3 at 10W 42 CW 14.257.90 NO-071 ATAS-TEST LSB 14.257.90 NO-072 AMTR-TEST LSB 14.257.90 NO-073 HTEMP-THRESHOLD 38 LSB 14.257.90 NO-074 FTEMP-THRESHOLD 102 LSB 14.257.90 Hope thia helped........kevin KC8IDG
Oct 21, 2008 | Radio Communications
FM Radio doesn't work
it may be that the fm detector has failed or possibly a tank(tunning coil)
Aug 31, 2008 | RCA RS2664 Shelf System
Realistic pro 2020 scanner
The Realistic PRO-2052 is an old (vintage) scanner receiver with fixed AM and FM modes on the bands it cover, as specified by the U.S. band allocation. The PRO-2020 covers only the VHF and UHF frequencies and modes AM and FM is not user selectable. Frequencies can be programmed into any of the 20 memory channels
U.S. Coverage: (varies from state to state and other countries. We don't use 30-50 Mhz here in the Philippines for 2 way mobile communications, except for cordless phones)
30-50 Mhz Lower VHF at FM narrowband only (covers mobile, emergencies, businesses, etc. and
cordless phones)
108-136 Mhz Aircraft band at AM narrowband only
138-174 Mhz Amateur and Commercial band at FM narrowband only (2 meter band)
410-512 MHz Amateur and Commercial band at FM narrowband only (70 cm band)
If you're trying to select AM or FM for a specified frequency, I'm afraid you can't do that as it is not selectable.
If you are trying to program AM Broadcast frequencies (mediumwave (MW) or FM Broadcast frequencies (FM radio stations), those were not covered by your PRO-2020's microprocessor. Even if you modify your scanner to receive those bands, you will not hear radio transmission properly since the receiver do not decode FM wideband, which is the standard mode for FM broadcast and Television band.
MANNY DE GUZMAN, JR.
SoundMagik Home Studio
Manila, Philippines
Visit my website at http://mannydeguzmanartist.wetpaint.com
My talents and modeling site at http://teenmodels2007.wetpaint.com
Jul 02, 2008 | Radio Shack Pro-2052 Scanner
Radio Communications Logo
133 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Radio Communication Expert? Answer questions, earn points and help others
