Question about Health & Beauty
SOURCE: it just starts and stops after few seconds ...
It sounds like either the compressor is bad, or the overload and relay assembly mounted to the compressor is bad. The easiest way to determine which is to put an amp meter on the power wire to the compressor assembly. It should only read a few amps while running. If it reads excessive amperage, you have a bad compressor. If you do not have an amp meter, then you could just go get a start relay and overload from a parts store and try changing those parts, as they are much cheaper and eaiser than changing the compressor....just unplug it before messinfg around inside the overload cover on the side of the compressor! Good Luck!
Posted on Oct 11, 2006
SOURCE: cpu fan starts then stops
I figured it out....... the cheap ass cpu fan went south
Posted on Jan 12, 2008
SOURCE: security system/battery
plz check the following and update me
1. Fuel (To be exact proper air/fuel ratio, normally it is about 14/1)
2. Spark (in appropriate moment)
3. Proper timing (the valves should open and close only in appropriate time)
4. Compression in the cylinders (Normal compression is 120 - 170 psi. The engine won't start if the compression is lower than 70 - 80 psi.)
Posted on Jul 14, 2008
SOURCE: horn
The Air Bag module in the steering wheel is no good. The contacts burn and stick.
Posted on Dec 22, 2008
SOURCE: horn on 01 silverado just stopped working
if the relay is clicking then it seems like it should blow. those trucks have a fuse box on inside of drivers door and under hood too. I would get a test light and go across both sides of the fuses and check to make sure none are blown. should be labeled horn. I think there are actually two horns one makes one note and one makes another so it is just about impossible for both to go out at the same time. try wiggling connection at horns themselves and see if it does anything. hope it helped.
Feb 26, 2018 | Cadillac Cars & Trucks
Jul 14, 2017 | Health & Beauty
Aug 22, 2015 | Heating & Cooling
Aug 11, 2015 | Health & Beauty
Jul 31, 2015 | Health & Beauty
Nov 16, 2011 | Dryers
Sep 06, 2011 | Singer Confidence 7467 Mechanical Sewing...
Aug 11, 2010 | Hayward 3/4hp Super Pump Inground Pool...
Jun 09, 2010 | Golden Technologies Golden CompanioN II -...
Feb 07, 2009 | Baby Lock Imagine
41 people viewed this question
