Question about Gucci Watches
I need fixing pin for stainless steel Gucci 105watch bracelet
Posted by Nila sorathia on
ray gallant
    Top Expert:
  • Gucci Master
  • 68,304 Answers
GO SEE A JEWELRY STORE . BEST BET TO FIND WATCH PINS
Posted on May 30, 2019
4 Related Answers
Anonymous
  • 55 Answers
SOURCE: I have a Navy Seals
parsecent.com...they have all the parts to fix it with and they also have to band-to-case piece that you've lost
Posted on Nov 09, 2009
Anonymous
  • 247 Answers
SOURCE: Alfred Dunhill stainless steel watch bracelets
This might help:
http://www.info.com/stainless%20steel%20bracelets?cb=27&cmp=4089&gclid=CLmY5aWk1aACFWV75QodumH8uQ
Posted on Mar 26, 2010
Bruce Robin
  • 300 Answers
SOURCE: I need a bracelet pin and the steel insert for a Montbrillant nav
Any jeweler that sell watches should have the springbars and tubes you need and be able to put them on for you for less than $10. If there's a Breitling dealer nearby that's your best bet but really any watch shop or watchmaker can help you.
Posted on Apr 24, 2010
Azrael SRL
  • 11800 Answers
SOURCE: Looking for Rado Diastar Anatom watch bracelet
The only source for separate original links is a repair shop that has a defective watch kept for parts. You could order an entire bracelet but that would be very expensive.
The cheapest solution is to get a copy like
http://www.flyingshops.com/rado-anatom-mens-watch-r10365151-4796-p.html
and use its bracelet.
Posted on Jul 13, 2011
Caravelle by bulova 43b17how to adjust Stainless steel bracelet
To remove some links: If you don't have special tool, at least you have to have something really hard and thin (like the pin you use to post notes on the cork board). Put that pin in to the tiny hole between links where the bracelet pin is and then press/push it forward (follow arrow direction as shown on the inside of the bracelet links.) When the bracelet pin comes out at one end, pull it out of that end totally.
After removing one links, connect the two links next to each other by placing the bracelet pin back into the hole and push it to the other end.
To add some links: You have to have spare links and do the same way with the pin to attach more links.
Feb 17, 2011 | Watches
Tissot Seastar 1000 Does anyone know of a source
Tissot is Swatch. They do not sell parts! You need to contact the company OR where you purchased the watch.
http://www.tissot.ch/?mod=stores&action=search&search=&regions=2&countries=195&countryregions=&option=cs
Jan 14, 2010 | Tissot Diver Seastar 1000 Auto Steel Large...
Seiko kinetic stainless steel bracelet has snapped pin (both snapped ends still visible and flush in last flared bracelet link between watch body and start of bracelet.) How do I remove snapped pin ends...
There are several easy to follow tutorials on u-tube. It's easier for you to look at these than for me to describe how it is done. Just search "adjusting steel watch straps"
Sep 23, 2017 | Omega Seamaster 2541.80 Wrist Watch
Adjust watch band for Seiko 7T94 Stanless Steel Band
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Apr 04, 2009 | Seiko Watches
Stainless steel band adjustment
Job done!
Mar 18, 2009 | Watches
Stainless steel band won't snap into my watch
Stainless steel bracelet ends (so called wings) must be curved flush to the watch case.
Another way is to use curved spring lugs (pins).
Dec 12, 2008 | Philip Stein Teslar Large Gunmetal Watch
Watches Logo
485 people viewed this question
Top Gucci Watches Experts
Janelle Schoonover
Janelle Schoonover
STEVE yes that one
Are you a Gucci Watch Expert? Answer questions, earn points and help others
