Question about Boating
Took a Kawasaki 24 horse with a 9 prong plug to a Briggs with a 6 prong plug how to wire it up
Posted by Justin Mccostlin on
5 Related Answers
Anonymous
SOURCE: I have a John Deere 265 mower.The problem I have
I fixed this problem myself. This alternator had a diode in one of the wires, just take it out,problem solved.
Posted on May 21, 2009
Jim Fowler
  • 23 Answers
SOURCE: dont know wich wires go to wich prongs on ignition
You can get a wiring diagram by going to a web site for OMC Motors
Jim OMC Retired Mech
Posted on Jul 07, 2009
Anonymous
  • 491 Answers
SOURCE: I just bought an Amana dryer and need to switch
THE BEST THING TO DO IS CUT THE THE 3 PRONG PLUG OFF WIRE AND REPLACE IT WITH THE 4 PRONG PLUG AND YOU WILL HAVE AN EARTH .
Posted on Nov 01, 2009
Phil Saunders
  • 110 Answers
SOURCE: have a 9 horse troy built 33in walk behind mower,I
The wire to the carb bowl is a fuel shut-off solenoid. Needs battery voltage applied while the engine is starting/running. Your ignition switch will need a 'load' connection (battery voltage when 'ON' or 'START', off otherwise.
If your ignition switch is not suitable, you will have to rig something.
Posted on Jun 23, 2010
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: what is the color sequence(left
http://acdelcotechconnect.com/pi/wiring-connectors/gm/pigtails/5-cavity/female/
2 switches are to be mounted in the center area, where driver and passenger can reach the both of them. Dremel out a space and slip the switches in. They have locking tabs on the side for a snug fitment. You will find 4-5 wires on the bottom of the switch; 5 wires if your switch is illuminated. Connect the 12volt wire to either and ignition wire or a 12 volt constant source. It depends on if you only want the windows to work with the car on or if you wish them to operate always. Now connect the ground wire to chassis ground or the negative battery terminal. If your switch is illuminated, connect the illumination wire to the parking light positive wire on your vehicle. This will illuminate the switch whenever the lights are turned on. There are 2 wires left over, these are your window motor leads. On your window motor, there are 2 wires, usually green and blue. Take one wire and put it to 12 volts constant. The other wire and put it to chassis ground. This will move the window either up or down. Make a note of which color was on 12volts constant when the window goes up. On your switch, there are 2 wires left. One connected to the "up" part of the switch, the other connected to the "down". Whichever wire on the window motor was at 12 volts constant when the window rolled upwards, connect that to the "up" location wire on the switch. Connect the "down" wire from the switch to the other wire on the same motor. Repeat for the other switch. Installing the 3 switch is basically the same, except you must add a separate group of wires. Wire everything the same as above, just run 2 wires from the driver side to the passenger side. Connect the motor leads from the passenger switch from the driver door and the switch on the passenger door together. This will allow the two switches to operate together. Then wire the passenger door switch the same as the driver. You should be complete.
Posted on Oct 27, 2010
Oil drain plug for 7.5hp briggs straton engine
If you're looking to obtain an oil drain plug -- your post doesn't actually say that -- I'd recommend your local hardware or plumbing or home improvement store. Briggs & Stratton generally uses standard iron pipe threading on their oil sump drains. You'll want a 3/8" IPT plug.
Aug 04, 2015 | Troy-Bilt Troybilt Horse 6, 7 And 8 Hp...
1997 Kawasaki VN 800 A Vulcan no spark
Hi, Steven and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting/leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty pulse coil.
8. Faulty CKP, CMP, or BAS sensor.
9. Faulty ignition switch.
10. Faulty run/off switch
11. Tilt sensor needs a reset.
12. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.kawasakimotorcycle.org/forum/mechanics-corner/155137-1997-kawasaki-vulcan-800-no-spark.html
How to diagnose no spark situation on motorcycle
KAWASAKI VN800 Service Manual
OEM Parts for Kawasaki
1997 Kawasaki Vulcan 800 Classic Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 10, 2012 | 1997 kawasaki VN 800 Vulcan Classic
24 volt trolling motor (motorguide) not working. Have 24 volts at receptacle in hull of boat but when I plug in the trolling motor and check the volts on the plug, I only read 6 volts. Any idea whats...
You have a high resistance short either inside the wiring or the lower unit. This will cause a voltage drop. I would be very careful not to keep it connected too long cuz the battery is trying to keep up with the current demand and may explode.
Oct 03, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
Have a 9 horse troy built 33in walk behind mower,I want to replace the engine with a another briggs a 15 horse, but it has some extra wires to the carburater bowl and I wnat to make sure where they go and...
Jun 23, 2010 | Garden
24 horse brigs with 100 hrs has no fire. Help
You can take the engine shroud off and clean the magnets on the fly wheel. Also clean the two little prongs that are close to the fly wheel. They will rust up and you won't get the pulse needed for the spark plug. With the shroud off check any wires that might be damaged. Mice like to make nests in the engines and love to chew on the wires. When cleaning the fly wheel magnets use emery cloth or fine sand paper. Also check the connector that attaches to the spark plug. In you didn't replace spark plug I would suggest doing so.
Good luck. Let me know if this helps.
roundo4
Aug 15, 2009 | Briggs & Stratton Garden
Dont know wich wires go to wich prongs on ignition
Jul 03, 2009 | Boating
Boating Logo
127 people viewed this question
Top Boating Experts
ray gallant
 vpsoccer
vpsoccer
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
