My concierge repeats songs and will not stay in shuffle mode...how do i fix this?
Posted by Lori Brady on
5 Related Answers
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: MP3 Shuffle
Do the 5 R's
Posted on Sep 05, 2008
Anonymous
SOURCE: Can't find shuffle button
if listening to a playlist shuffle is disabled. If just playing from the music file shuffle options should be available
Posted on Jan 12, 2009
Anonymous
SOURCE: iTouch replays same song over and over unless manually forward
Did end up fixing this by doing a reset of the settings on the iTouch. Working fine now.
Posted on Feb 03, 2009
ddogg871
Derek Powers
  • 132 Answers
SOURCE: Even when on shuffle, my itouch repeats the same song.
On the now playing screen click the icon in the top left (looks like 2 arrows in a circle) and it will turn repeat off.
Posted on Feb 19, 2009
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: Phillips SA3125 2GB "shuffle all" problem.
I would go ahead and try the firmware update to see if it resolves your issue - for the firmware update to work, you have to get the most recent version of the Philips Device Manager from Philips website. It will erase all the songs in the GoGear, so make sure you have them backed up.
-Tha Mp3 doctor
Posted on Mar 07, 2009
I bought an AGPTEK GO2s and carefully downloaded 31 complete albums in the order they were released. But the player is playing ALL the songs out of order. What do I need to do in order to fix this.
4. Play mode - While it's on music playing interface, click the (button in the blue box) to access to its sub-menu. - Choose from the three play modes "Repeat", "Shuffle", "Repeat Settings" according to your need. Note: The shuffle/repeat function only works for the audio files in each separated folder.
http://images.agptek.us/Download/mannual/A12%20EN%20Manual.pdf
26354717-1xgjsougzksfoatycggrr2j0-2-2.jpg Hope this helps?
Nov 14, 2016 | Audio Players & Recorders
How do I shuffle songs on my Bush MPK8099BUK MP3 player?
If you set the play mode to shuffle. It should shuffle whatever you are playing, be it All Music, An album or a playlist.
you can set the player to shuffle by pressing the "M" button. from the menu choose "Repeat" mode press "Previous/Next" to scroll through the options until you get to "shuffle". [Press "Play/Pause" to confirm and press M to return to sub menu.
Aug 04, 2011 | Audio Players & Recorders
Need to know how to shuffle my mp707-2g
Lacks sufficient Amplifier Gain, (max volume of 25 is hardly comparable with other players), File navigation is primitive with only Shuffle, Sequential Mode options. The shuffle mode is lacking there is no repeat memory so songs are often repeated in the
Read more: http://reviews.cnet.com/mp3-players/panasonic-sl-mp70/4505-6490_7-20795155.html#ixzz1QRR9Nd9Q
Jun 26, 2011 | Coby Audio Players & Recorders
My mp3 only plays the first song how can I get it to play all songs?
You've accidentally turned on "repeat" or "repeat 1" mode. If it has a "mode" key then press it until you cycle through "repeat all" and/or "shuffle" and/or "shuffle repeat" until it says nothing. If you have a cheaper player, the "play mode" function may be hidden in a menu somewhere, to save the physical button. Check around in the menu/settings to see if you can find it, or, in the last resort, check the manual.
Jan 19, 2011 | Audio Players & Recorders
Songs keep playing twice. How do I turn off the
If you tap the screen while a song is playing you are presented with a set of controls that allow you to set the repeat mode for the album or list, change the shuffle mode and seek forward and back through the current song.
Jun 05, 2010 | Apple iPod touch
How to set a song to repeat over and over
It's in the friggin manual:
You can set your player to play songs randomly (Shuffle All ) or repeatedly (Repeat
One
or Repeat All ).
1 From the main menu, select > Play mode.
2 Press 3 or 4 to scroll up or down the options.
3 Press 2 to select an option.
While you are playing music, you can see the above active play mode screen.
The full manual is available at:
http://www.p4c.philips.com/files/s/sa6045_37/sa6045_37_dfu_aen.pdf
-Tha Mp3 Doctor
Dec 03, 2008 | Philips GOGEAR SA6045 MP3 Player
How do I access shuffle mode??
I think I found the solution... to get into the "playing mode" submenu, a song has to be playing when you hit the mode select button. Otherwise, if a song is stopped/paused, you get the "stop mode" menu.
Once in the "playing mode" menu, select "repeat", and then scroll all the way to the right to get the shuffle/random mode.
Feb 06, 2008 | Delstar DS 31024 MP3 Player
Samsung yp-u2j shuffle
Hold Down The M (Menu button) Scroll down to settings, select play mode. Exit out of he menu, press the user button until the squiggly cross with the A appears. Whalaaa you're in shuffle Mode. I hope this was a detailed solution.
Jun 14, 2007 | Samsung YP-U2JQB MP3 Player
if you press the tool button and then go to play mode when your on the screen that comes up when the music is playing there should be an option to do many types of shuffle including all songs or just the songs in that folder.
Sep 06, 2006 | Samsung Yepp YH-J70 Digital Media Player
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
