Question about Mitsubishi Heating & Cooling
I have a P4 error on a Mitsubishi Mr slim inverter wich is a pump error but ac does not have a pump,any dip switch I need to set?
Posted by Gerhard Feldtmann on
Thomas Woodburn
  • Mitsubishi Master
  • 2,410 Answers
Should have a dry contact on the board, cant remember what number (m4?), possibly loose wire or cut. Put a jumper and see what happens
Posted on May 30, 2019
5 Related Answers
francis rivero
  • 958 Answers
SOURCE: Mitsubishi Mr. Slim Mini Split MS-A12WA Indoor Unit
no sir gary,
the water would not go to the drain pan if you install it vertically.
water would just drop anywhere and would ruin a lot of things...
tnx 4 using fixya,
drcool
Posted on Sep 13, 2008
Anonymous
  • 27 Answers
SOURCE: Mitsubishi Mr Slim air conditioner
get model and serial #s and look up unit for diagnostic codes
Posted on Nov 26, 2008
Anonymous
  • 128 Answers
SOURCE: Replacement compressor for Mitsubishi Mr. Slim Air Conditioner
pls no overhauling repair no spare part avaliable for hermetic comp[ressor the right is to change it
Posted on May 02, 2009
Anonymous
SOURCE: replacement remote for Mitsubishi Mr. Slim AC
I CHECKED FOR ONE THEY WANTED 75 FROM MITSUBISHI TO REPLACE BUT I GOT UNIVERSAL REMOTE ON EBAY FOR 12 DOLLARS IT WORKS GREAT!
Posted on Jul 26, 2009
Anonymous
SOURCE: Mitsubishi Mr slim Airconditioner error check P8
I Have same problem
Posted on Sep 28, 2009
Preset heat stuck at 63. I want to lower the temperature for a vacation
[PDF]PAR-30MAA - Mitsubishi Electric Australia
https://www.mitsubishielectric.com.au/.../IB_PAR-30...
Mitsubishi Electricand Mitsubishi Mr. Slim Air Conditioners. MA Remote Controller ..... Heat. 17 ~ 28 ?C (63 ~ 83 ?F). Auto. 19 ~ 28 ?C (67 ~ 83 ?F). Fan/Ventilation. Not settable. 13 ...
[PDF]PAR-31MAA - Mitsubishi Electric Australia
www.mitsubishielectric.com.au/.../par-31maa_ib_en.p...
Mitsubishi Electricand Mitsubishi Mr. Slim Air Conditioners. MA Remote ..... Heat. 17 ~ 28 ?C (63 ~ 83 ?F) .... Preset cooling temperature is higher than preset heating temperature.
My air recycle button just blinks. Also when i turn on the - Fixya
www.fixya.com/support/t26081705-air_recycle_button_just_blinks_also
6 hours ago - Not sure the heat pump is producing enough heat. Nov 04 ... Preset heat stuck at 63. ... Feb 05, 2016 ' Mitsubishi Electric Mr Slim E12C26426.
[PDF]MA Remote Controller Mitsubishi Electric PAR-21MAA ...
planetaklimata.com.ua/.../Mitsubishi_Electric/Mitsubishi_Electric_PAR-2...
Easy Maintenance Function (Only for Mr. SLIM PUHZ series) . .... 4.4.3 Automatic Cooling/Heating Display Setting . ... Monitoring the Operation Data by the remote Controller (for Mr. SLIM) .......... ..............48 . How to .... 63. 4.2 How to set rotation function(back-up function, 2nd stage cut-in function) . ... Preset temperature (. °C. ).
Feb 05, 2016 | Mitsubishi Electric Mr Slim E12C26426...
Mr slim ac shuts down and restarts to frequently.
Changing the setting won't affect the way the unit works, only how long it runs for. Rapid switching off and on will kill your compressor in time - check the refrigerant level. Usually short cycling on lp switch.
Oct 19, 2014 | Mitsubishi Mr. Slim MXZ30TN Air...
What are the dip switches for on the circuit board of the outside unit of the Mr.Slim PU30EK
You need to refer to the PU30EK manual for these dip switch settings.
Sep 16, 2012 | Heating & Cooling
Mr. Slim aint cool!
Unit short of refrigerant or outside condenser very dirty. Clean outside thoroughly and make sure there is plenty of warmth coming from it when working.
Jul 07, 2012 | Mitsubishi MSZ-D30NA Mr. Slim Wall Heat...
What mode do I set my remote in for heat?
You can press the mode button until the indication in on the icon wich look like a sun, a circle with lines around it
Dec 24, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr slim Mitsubishi - how much fill
On the data plate for the outdoor unit it will tell you what type and how much refrigerant you need. If the line set is longer than 25 feet you will likely need a bit more than what it says. A 40 degrees evaporator temperature is ideal, approximately 65 psi for r22
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Mar 31, 2017 | Mitsubishi Mr. Slim MXZ30TN Air...
Ac unit shuts down
See this document for P8 code on Mitsubishi Mr Slim MXZ30TN... It is likely you can get the fix just from following the diagnosis steps 1-7. http://www.digelair.net/pdfs/TECHLIT/MITSUBISHI/MrSlim_P-SERIES_Troubleshooting_TIPS.pdf
Jul 02, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
MR.Slim heater - NO HEAT??
make sure you have freon in your system. they act as a heat pump which does A/c as well s heat. without freon you want have cooling or heat.
Jan 17, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
76 people viewed this question
Top Mitsubishi Heating & Cooling Experts
Marvin
Marvin
NOEL
NOEL
Vernon Taylor
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
