Question about Jensen Audio Players & Recorders
Jensen JCR-315 manual - Jensen Audio Players & Recorders
Posted by John Carrick on
Terry
  • Jensen Master
  • 11,377 Answers
4 Related Answers
Anonymous
  • 215 Answers
SOURCE: how to set radio stations in jensen JCR 280
9 times out of 10 you just have to go to the station and press and hold the number you want that station to be programmed to
Posted on Jun 07, 2009
Anonymous
SOURCE: Just need to know how to set the time and Alarm
the 3rd button on the first row said stop/TIME
it only works as "STOP" when the "FUNCTION" knob is on CD otherwhise is the "TIME" setting button akong with the "MINUTE" & "HOUR" buttons in the same row
Posted on Jul 09, 2010
coolfelix
  • 39 Answers
SOURCE: please give me link for instructions for jensen JCR-425 clock radio
To preset a channel on the JCR-425, you tune in the channel; press the "AL/MEM" button on top of the radio (at which time you will probably be switched to some other radio frequency, which is rather disconcerting), press the "Up" or "Down" button to select the desired preset channel number, press "Set" -- and only then are you returned to your desired radio station. If you want to preset several channels,
You might then think that the next time you turn on the radio that all you would have to do is press one of the 10 preset channel buttons on the front of the radio to visit one of your preset radio stations. You would be wrong. You must turn on the radio, then press the "AL/MEM" button on top of the radio. Only then can you access your preset radio stations.
You might also think that to turn on the radio you would press a button that says "Power." Wrong. You press a button that says "Radio." Well, okay. But you might think that to turn it off, you would just press the "Radio" button again. Wrong. If you have pressed the "AL/MEM" button to access your preprogrammed channels, pressing the "Radio" button simply takes you out of the "AL/MEM" function and back to the "FM" (or "AM") function, apparently taking you back to the last radio station you tuned in manually. To turn off the radio after accessing a preset channel, you must press "Radio" twice.
Posted on Dec 22, 2017
emissionwiz
Marvin
  • 85239 Answers
SOURCE: How to clean the tuner on Jensen JCR-560?
They make a special spray for that purpose.
Posted on Apr 06, 2018
We had a power failure after a few power surges and now I cannot set the clock. The display keeps blinking rapidly. How can I set the clock?
Jensen Smart Talk JCR 290 User Manual Page 10
USING MANUAL SETTINGS
In radio off mode, press SET BUTTON (#5) to enter AL1/AL2/Time
setup mode.
1. The HOUR DIGITS and AL1 indicator in the LCD panel will flash.
2. Using the > (UP) (#6) or < (DOWN) (#4) BUTTONS, adjust to the
desired hour for AL1.
3. Press SET BUTTON (#5). The MINUTE DIGITS and AL1 indicator
in the LCD panel will flash (#25).
4. Using the > (UP) (#6) or < (DOWN) (#4) BUTTONS, adjust to the
desired minute for AL1.
5. Press SET BUTTON (#5). The SOUND EFFECT INDICATORS of
AL1 will flash (#25).
6. Use the > (UP) (#6) or < (DOWN) (#4) BUTTONS to choose a
Wakeup Alarm Sound - Ocean, Rain, Brook, Radio or Beep Alarm.
Jensen Smart Talk JCR 290 User Manual Page 9
2helpful
2helpful
How to set radio stations in jensen JCR 280
Jensen JCR-550 manual
Get it on internet,type www.jensen.com and download the manual is free.
16helpful
2answers
NEED HELP SETTING THE TIME
i had the same issue; with a little bit of experimenting I was able to set the time. Hold down the stop/time button until it displays 12A (it might display 24H first - do it again if you don't want military time to get the 12A) Let go then press stop/time again so the time blinks. Use the hour and minute buttons to set the time appropriately. When satisfied, press the stop/time button again.
1helpful
2answers
No manuals - difficult to figure out
go to Spectra Merchandising Intl [[email protected]] Spectra is the company that sells the Jensen. I e mailed them asking for a manual and they e mailed it by the next day.
No FM Reception
So what is the question? send it back ASAP. As far as i know there are a lot of problems with Jensen CDs...
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
 Francisco Mauricio...
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
