Question about Jacuzzi Home
My Jacuzzi tub is not working and I'm not sure whether I need a new button, whole control panel kit, or switch. Thoughts?
I have a Jacuzzi Cetra R100. It stopped working. I filled the tub and hit the button to turn on the jets, but it would not turn on. I emptied the tub and about an hour later it started out of the blue. I was able to turn it off. Next time I tried to use it, it turned on but I couldn't turn it off, so flipped the circuit breaker. The covering of the button you depress has broken off, but you can still depress the button. Not sure if I need a new button, whole control panel kit, or switch. Thoughts?
Posted by Alan on
Keith Bowers
    Habit-Forming:
  • 153 Answers
Contact the Dealer and seek qualified tech service. Risk of electric shock/***** You should not take the risk but have a QUALIFIED SERVICEPERSON perform the work.
Posted on Jun 29, 2019
5 Related Answers
keith rodriguez
  • 15 Answers
SOURCE: my bathtub jacuzzi wont work. I reset the circuit
make sure you have power to outlet that motor is plugged into,if so try pushing jet button in tub about ten times in a row quickly then on tenth push use as much force as possible and hold.if this does not work,air hose from back of button to pump motor may be disconnected.
Posted on Oct 04, 2009
A Miller
  • 8404 Answers
SOURCE: I have a jacuzzi corner tub. The control panel
I would expect there is a Jacuzzi dealer in your town and I would guess he has parts. If you purchase parts locally, not only are you helping your neighbor but also, you will have the opportunity to pick his brain on tips to install.
Thanks for your interest in FixYa.com.
Posted on Feb 20, 2010
Anonymous
  • 41 Answers
SOURCE: We have a new Jacuzzi tub and went to turn it on
check to make sure the pumps on and that its wired correctly and that all valves are open.
Posted on Mar 03, 2010
uspartscente
US Parts Center
  • 719 Answers
SOURCE: I have a whirlpool jacuzzi tub. I wired to diagram
Sounds like you may not have a ground on the motor of the pump or a grounded outlet?
check the wiring on the motor on the cord to make sure there are no wires improperly attached inside the motor housing.
Posted on Jan 12, 2011
uspartscente
US Parts Center
  • 719 Answers
SOURCE: I don't see any start
Fill the tub with water. get it in. touch the Logo.
Posted on Feb 01, 2011
What causes my jacuzzi hot tub to turn itself on.
sounds like you have an electronic system that operates the tub. Many times those get hit with a voltage spike and it burns up a relay on the circuit board and THAT is what make them come on at weird times.
You will most likely need a new control for your tub.
Jan 04, 2011 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
My jacuzzi works fine but the air button seems faulty as turning it makes no difference. The clear tube is connected to the box on top of the motor. Any thoughts?
Lots ot time a small spider nests in the tube or switch body. If you can detach the tube at the switch and run a pipe cleaner down to clear the web, that might help. also look for cracks or holes in the tubing.
May 01, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Where can I buy new starter button
if it is just an air switch you can get one just about anywhere. You may have to do a little modification but it should work.
Apr 11, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Feb 22, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Feb 20, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
I am trying to replace the bellows(on/off switch) on my jacuzzi tub. I cannot get the oldone removed.
air button body's are threaded and there is a nut on the under side of the body that holds it in place.
Jan 17, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jacuzzi tub wont power off or on by push switch to turn off or on i have to use power supply
The button is worn out. It should be a relatively inexpensive repair whether you do it yourself or have a technician drop by.
May 17, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Home Logo
189 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Bill Johnson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
