Question about Homedics Health & Beauty
SOURCE: my homedics back massager with heat, stop working
the back massager with heat stopped working, bought a new power cord, still does not work, must be something in the back massager, but what to do ? ken
Posted on Apr 10, 2009
SOURCE: Can't disassemble massager.
I don't have the Homedics programmable, but I have taken apart my Brookstone programmable (and lots of old Homedics massagers).
I'm going to guess the screws concealment method is similar. On the under side of the massager, look for small oval-shaped outlines that are the same color as the rest of the body. Mine had four. These are little plastic plugs that you can pry out with a tiny flat screwdriver or a razor blade. The screws are hidden under these plastic plugs.
I hope this helps
Posted on May 25, 2009
SOURCE: remote doesnot work
If you have not already, register your product with the company. And contact them regarding the malfunction. they should replace the part or the product if you send it in.
Posted on Jun 09, 2009
SOURCE: Massager Parts
Wow , I've never hear of wearing out the balls - I dunno.
Posted on Apr 24, 2010
SOURCE: I've plug the 110-v Homedics massager into
I managed to get it fixed this weekend.
What I basically did was , I
opened the cushion that was basically zipped up , then there was a plastic
casing which was easily removable by unscrewing the screws.
then if you
follow the power chord , you will find that it is attached to a pcb . This is
the adapter. This adapter is then connected to another pcb through an easily
removable power clip. What I did was I took this to an electrician . The whole
unit looks like a laptop power adapter , but without tHe outer black casing. If
you stay in bangalore you can take it to sp road, there's this shop that works
on speakers. The electricitritian told me that a capacitor and something else ,
I don't remember , had blown up. He replaced it and it started working with a
120 / 220 volt 50 watt voltage converter. I have MCS-700H, check what is your
power rating, its written the label which is in the seat of ur massager. If ur
not sure buy one with 100 watts .
Hope this helps!
Btw it cost me
300 to repair and 200 for the voltage transformer.
Posted on Apr 02, 2012
Mar 17, 2018 | Homedics Health & Beauty
Oct 02, 2011 | Health & Beauty
Jul 08, 2011 | Homedics Health & Beauty
Dec 16, 2010 | Homedics Shiatsu Massager
Nov 30, 2010 | Homedics Health & Beauty
Jun 30, 2010 | Homedics FOOT MASSAGER ULTRA DEEP KNEADING...
Jun 20, 2009 | Homedics Inc Massager Neck Massager W/heat
Jan 19, 2009 | Homedics Inc Massager Neck Massager W/heat
