Question about Music
Instrument can I have it
Keyboard Mike's mixer Grimes
Posted by Prof Sibeko on
How to connect my mixer to my guitar combo
You don't mention the make and models of the gear you're asking about, so we can't address your pacifist setup. However, most mixer outputs are going to be at line level, whereas a guitar amp inputs are instrument level. Line level is way hotter than a guitar amp can handle. You need to find a mixer that has a -10dB output to do what you're asking.
Jun 24, 2016 | Music
How do i connect my keyboard and my laptop?
Download USB MIDI driver for yamaha from yamaha website,and install to laptop.
Next:
Make sure the POWER switch on the instrument is set to OFF,then use an AB type USB cable to connect the instrument to the laptop.
After making the connections, turn on the power of the instrument.
Laptop will immediately notify that new hardwares is connecting and automatically install the drivers. Wait until the process is finish.
Thats all. In Ableton,the setting MIDI input must be set to USB MIDI.
Aug 19, 2015 | Yamaha PSRE413 Keyboard
Will amp still work after third prong is broke
If the third prong is the round one, then that is the ground to your amp. It will still work, however, the amplifier will not be properly grounded. So in a pinch you can use it, but you need to get the cable replaced. The ground wire is there for your safety, in case you plug your amp into a mis-wired outlet or if you are plugging in another instrument like a keyboard, mixer etc. that may be mis-wired. This could lead to a bad shock or worse. You have been warned.
Apr 22, 2014 | Roland KC550 Amp Keyboard
When was this manufactured
Well, first, we need more information:
First, what kind of instrument has this serial number- Guitar, keyboard, mixer...
Next, is there an available model number?
Last, if there isn't a model number, can you give a general description or the instrument?
Jun 23, 2013 | Music
What is the best way to run a Bass thrue the mixer , Mike the Amp or directley thrue the mixer, we had problems with a clear sound?
The easiest way is to take the line out from the bass amp and connect it to the line in socket of the mixer ( not the XLR Mic in ). This will give a clean and flat sound which you will have to customize using the Mixer tone control and not the bass amp controls.
May 01, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
How do you connect a Boss ME-70 pedal to this mixer.
Since the pedal is for one instrument only, your guitar should go through it and a Balanced TRS cable should go from the pedal to one of the 1/4 inch LINE inputs on the mixer.
Jan 23, 2011 | Behringer XENYX 2442FX Mixer
The sound on my synths is not working. I just bought reason5, and all that makes noise is the kong drum machine. I am very new at this so it is probably a stupid problem, but whenever I pull up the...
okaye, i justt figured itt outt, hopefully you gett an email aboutt this postt...
so anywayz yo,
how many instruments you have hooked up to your mixer? thats the key, #1.
make sure you have atleast ATLEAST 2 mixers in your start up program, once you use the max output input for your original mixer, the next instrument patch you load will not be routed, (no more space), you'll have to route it manually (press Tab) *get familar with routing your own devices, for reverb/chorus and such,
this applies to everything about recieving sound from your project/keyboard. and just route your extra devices on the new mixer --they go up to 14 channels, i have like 22!
so thats my solution, hope itt applies.
Dre'
South Caro-line-em- up
~1~
Jan 16, 2011 | Propellerhead Reason 5
I have speakers plugged into my phonic powerpod 820 right now but I want also to have the output of the mixer to go through an instrument amp, is this possible? If so, where do I connect the instrument amp...
Yes it's possible. I'm assuming you'd like to use the keyboard amp as a "monitor". In which case, take a 1/4inch TS (instrument cable) jack out of "Aux Send" into the input of your keyboard amp. Make sure the keyboard amp is turned up to a good level and that the Master SEND is turned up on the Desk.
Now you can make your own "monitor mix" for on stage use without effecting the F.O.H mix by turning up the aux pot (knob) on each channel you use.
You can use the CTRL ROOM output also, but make sure it's not giving a "Powered Output" from the internal amplifier in the mixer as you will damage the keyboard amp.
Jan 16, 2011 | Phonic Powerpod 820 / S712 PA Package
I am keyboard player and i want hook up an equalizer to the system where do i hook it up to
If you're only using the keyboard, connect the keyboard output to the EQ input, and EQ output to your amp.
If you have multiple instruments and a mixer, run mixer output to EQ input, EQ output to amp.
More info, let me know.
Charlie
Aug 29, 2009 | DBX 231 Dual Channel 31-Band Graphic Eq
Yamaha Keyboard Microphone Not Working
Hi Simon. Has the cable to your Mike been trapped under the stand, trodden on etc. Could be a faulty plug or even Mike/switch. Did the Mike ever crackle under use?
Have you another Mike and lead to try?
Sorry for the obvious questions but I have seen this happen before and it was a faulty lead...
Dec 18, 2008 | Yamaha Full-Size Keyboard
Music Logo
131 people viewed this question
Top Music Experts
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
