I need sponsor for my church instrument to sing keyboard speakers microphones anagrams please help me
Posted by Prof Sibeko on
3 Related Answers
Anonymous
SOURCE: Magic Sing EG-18000 Microphone Delay
but how do the other competing products work ok on Plasma tv, Why does the magic sing have a problem?
Posted on Jan 10, 2010
rexark
rexark
  • 55 Answers
SOURCE: Hi everyone, i am a vcliast and have been singing
This can be a tedious process if not done very methodically. Be sure to turn up your room volume carefully. While you will find many people who will "jump" to the part of giving advice about "ringing out" monitors, which means small adjustments are made to try to target the exact frequencies where the feedback is heaviest, this is not at all where you should begin. You should begin in the simplest way. Make absolutely certain that your speakers are in front of, not behind, any and all microphones. Moving the speakers (monitors) forward even just a few inches can make an enormous difference. Speaker placement is absolutely the most important aspect of preventing feedback. Place your speakers as close to the audience as possible with safety in mind, to reduce the required volume. Even consider placing one or two speakers halfway back into the room to get them closer to the people sitting in the back of the room. Never place speakers in the corners of the room or right up against walls.
I have produced several video clips available on facebook under the profile whamuniversal, and a full-length DVD which goes into further detail, which is available at www.rexark.com.
Posted on Mar 05, 2010
djlaplaya
dj LaPlaya
  • 74 Answers
SOURCE: Our Baldwin electric church organ is over 30 years
Probably worth getting a new one. Try the keyboards from yamaha, they have good organ sounds.
Posted on May 06, 2010
How to use the micphone on the singing machine
Plug in the microphone to the provided jack. Adjust the microphone volume level not feed back and haul. Adjust the echo control to your choice while singing in to the microphone. Start singing while keeping the mike away from speakers.
Nov 19, 2017 | The Audio Players & Recorders
I Purchased behringer c1 u microphone and I want to record my singing with karoke..Problem is that when I connect laptop with speakers my singing volume is coming louder but sound of background music is...
You need a mixer. Connect the microphone to the mixer and also the background music. That way you have separate control of volume for the voice and the music.
The background noise can come from different sources. One of them is from the laptop itself, if the laptop is noisy to begin with.
Mar 14, 2014 | Behringer C1U Microphone
I have a Behringer B1 Microphone and a Behringer 1202 Mixer. I want to know how to connect both of these to my Yamaha Home Theater receiver so that I can sing karaokes from the computer, Please help
You'll need to connect both your PC and the Mic to the mixer, you'll need phantom power switched on at the mixer for the mic to work, you then take the two track out to the Aux input on the receiver.
Jan 30, 2014 | Behringer XENYX 1202 Premium 12-Input...
I am a good singer but i dont have sponsor
there are a lot of sponsors out there at the moment, i also sing and first tried the local paper then tried the local pubs /clubs etc.
Dec 02, 2013 | Rear Fender Sponsor Decal 2012
I get little sound out of the microphone spots onm my DA-X10Pro. I have a karaoke THE SINGING MACHINE. When I use my karaokee machine mic plug in the mic works fine...but any voice into the mic...
The mics on the singing machine are very low end mics and MAY not work on your other unit. The Voco has very sensitvie inputs to use with "professional" type microphones. The Singing machine mics are going to be fairly high output and likely to overload the voco inputs. Procure some professional mics like Shure, AKG, Sennheiser or others and don't forget to use a balanced to unbalanced adapter or cable on the mics.
Jan 06, 2011 | Vocopro DaX10pro
I bought rock band 3 for wii. I plugged in the dongle for the keyboard and followed the sync instructions exactly. the lights flash on both devices, but when I let go of the sync buttons, the lights on...
This can be frustrated the first few times. Here's the likely issue: the wii version will not activate the keyboard (or drums) if multiple wii remotes are active and all-instruments mode is not enabled.
The multiple wii remote thing: one remote is considered the microphone, and the rest guitar controllers (you can use the wii-remote based wingman and guitar hero guitars with this title). Once you get to two plus wii remotes on, you can't add more.
So, assuming one of your guitar controllers is active, use it to go into the menu system and turn all instruments mode on. Once done, a wii remote is no longer needed to be used for singing, and now singing will be turned on by default (but you can ignore it). Now, your drums and keyboard should work fine.
Eventually, the game smartens up and turns on this mode automatically for you, but the first few times it does not. I nearly threw the game out the window the first day or so.
Dec 31, 2010 | Rock Band 3 Wireless Keyboard
Very low sound output of melody
check the users manual,there is an instruction on how to adjust the level of the background music.
May 27, 2010 | Magic Sing Along Consumer Microphone
23 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
