Question about Life Fitness Exercise & Fitness
I have Life Fitness 95Te with next I have Life Fitness 95Te which shows next errors on Interface Board:
I have Life Fitness 95Te with next errors: 1. Notify Maintenance!System Comm Test Unavailable! 2. System Comm Init Timeout! Interface Board Not Detected! 3. Lost Communication with Interface Board 4. Notify Maintenance.Motor Controller Error. (Low Voltage Can you help me how to fix it? Treadmill doesn't work, now. Thank you very much.
3 Related Answers
Anonymous
  • 16 Answers
SOURCE: Life Fitness Treadmill "FET" error
Can you please provide model of unit.
Posted on Feb 20, 2010
Anonymous
  • 83 Answers
SOURCE: life fitness treadmill display: transistor error-won't run
This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
Solution
Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
Posted on May 07, 2010
mbartell
  • 3 Answers
SOURCE: On display stands: MOTOR COMM BAD
Try Carolina Technical Services in South Carolina for all you East Coast guys. They charge flat rate of $175.00 and have a 90-day warranty. Also great turnaround time. Carolinatechnicalservice.com. 864-504-7303. Sure beats sending to California and having to wait for 3 weeks.
Posted on Jul 04, 2011
Display screen says waxer disconnected how do I fix
Remove the motor cover and look for the Wax lift board , it's right by the motor controller and check all wiring going to it.
Mar 01, 2015 | Life Fitness "Remanufactured 95Te...
What does activity zone keypad not detected mean
This means either the keypad is faulty or it has come unplugged. Check for loose 10 pin connection at display console or wax/lift control.
LifeFitness 95TE Treadmill Parts SPORTSMITH net
Jun 05, 2014 | Life Fitness 95te Treadmill 7 Inch Touch...
Activity zone keypad not detected
This means either the keypad is faulty or it has come unplugged. Check for loose 10 pin connection at display console or wax/lift control. LifeFitness 95TE Treadmill Parts SPORTSMITH net
Life Fitness 9500HR Console Reads Motor Command Error and the Red Led #1 is not flashing.
motor controller board has error comunicating with console, you can try to disconnect all leads connecting to console and reseat. failing that you would need to send off board for repair as new motor controller for next gen model is 700 gbp.
May 30, 2014 | Life Fitness 9100 Next Generation...
What is the message mean "Frame Tag Unplugged"
it means the board with serial number is not plugged in or faulty.
normally in motor cover next to motor controller
Oct 29, 2013 | Life Fitness 95Te Treadmill
How to access to life fitness treadmill 95te menu
Hold down the PAUSE Key and press CLEAR Key twice. Continue to hold the PAUSE Key until the SERVICE MENU appears. Use the Speed UP/DOWN key to scroll through the menus and the ENTER key to make a selection. Once finished CLEAR button twice will reset the machine for use.
Oct 09, 2013 | Life Fitness 95Te Treadmill
I have a life fitness 95Te and can not reset the wax bag notification on screen. i'm told to hold the pause button then press the clear button. I don't have a CLEAR BUTTON!!
Dear Si:
Please go to the pag 48 from your user manual. If you do not have the user manual. go to the next web page: www.fitness.manualsonline.com and download for free, and follow the instruction for reset your wax bag device.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Feb 15, 2012 | Life Fitness 95Te Treadmill 95 Te
Exercise & Fitness Logo
166 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Vincent G
Vincent G
Thomas Perkins
Thomas Perkins
gbob59
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
