Question about Altec Lansing Audio Players & Recorders
Needed adaptors for altec lansing bx1020 please help me find.thank you
Anonymous
SOURCE:
Open SKy
Carlos L. Burgos
  • 620 Answers
SOURCE: one drive for Altec Lansing Technologies Inc. 'ACS-295' dell
Hello there
What kind of help on specific device from altec you need?
be more specific
Posted on Nov 29, 2007
Vj24601
  • 4 Answers
SOURCE: What's the volt & amps of Altec Lansing AVS300 2.1 speaker system
Your adapter is Part No. AVX300-A6859, Model No. 9701-00748-IUND.
Or You could get a universal that is rated for output of 18volt DC, 650ma, Center Positive.
I have used a 15volt DC, 900 ma with no problem, but I never run the volume high.
Good Luck
Posted on Dec 04, 2008
Anonymous
SOURCE: lost cord!
I have them for sale AC Adapter For Altec Lansing speakers inMotion iM600.Price is $15.95 Plus $6.95 shipping . send me your email and address to this email [email protected] and I will invoice you through paypal. Thanks
Posted on Mar 29, 2009
Alan Peterman
  • 7 Answers
SOURCE: output board for Altec Lansing ADA995
I've managed to fix the amp in the ADA995 when I blew the rear channel amp. There is a design fault with the voltage regulator that causes it to run very hot, which frys the plastic housing glued near it, which corrodes the circuit board trace.
Getting the sub/amp apart is a *****. But doable. You need to not only remove the screws in the back under the flat grills, but ALSO 3 screws behind the top speaker that also hold the amp in place. And getting the power supply out is another rather difficult procedure, which is needed if you want to run the amp on the bench to troubleshoot.
The amp chips are available, though no NTE equivalent, and replaceable.
Posted on Apr 22, 2012
Thomas S Christo
  • 28 Answers
SOURCE: Need the pairing code for bluetooth device to my Altec Lansing
0000
Posted on Aug 01, 2013
My altec lansing bx1020 is not working after i upgraded my pc to windows 7.
The problem is not with your speakers.
When you upgrade to a new Operating System, sometimes your hardware is not recognized correctly by the new OS.
In your computer, the sound card is not installed correctly. Search for Windows 7 sound drivers for your sound card and install.
If you think the problem is with your speakers, you can check by connecting them to another computer or an audio device.
Sep 11, 2011 | Altec Lansing BX1020 Computer Speakers
Bx1020
Sorry but this is not enough information to assist you, please elaborate what problem you are having.
Best of luck
May 25, 2011 | Altec Lansing BX1020 Computer Speakers
I just bought altec lansing bx1220 speakers but cant find device drivers to get them to work
shouldnt need drivers if sound was alredy working on cpu,,download audio driver for your computer at website of manufacturer of cpu,,
Nov 03, 2010 | Altec Lansing BX1020 Computer Speakers
My speaker does not woks....no power supply to speakers
If your speakers do not have a power light when plugged into an outlet for a source of energy, and you don't even hear a power-up sound when turning them on, this means that the speakers need to be replaced.
Hope this helps. :)
Oct 02, 2010 | Altec Lansing BX1020 Computer Speakers
I plugged my 110 volts Altec Lansing speakers into 220 volts :( How can I fix it? Please help me. Thank You.
Check fuse, but if there wasn't a fuse , your Altec need repaired to fix broken components in power circuits, could be the resistors, diodes or even transformer.
Jul 03, 2010 | Altec Lansing BX1020 Computer Speakers
Can't hear any sound
check your connections properly
or install correct audio drivers
or check your speakers...
May 20, 2010 | Altec Lansing BX1020 Computer Speakers
My altec lansing speakers BX1220 will not work with windows xp. it says there is no device. help
the usb cable is for powering the amp it does not carry audio, there's a 3.5 mm plug that connects to your sound card. also, no matter what anyone tells you, there is no driver download for these speakers.
Feb 21, 2010 | Altec Lansing BX1020 Computer Speakers
Computer not seeing Altec Lansing BX1020 speakers
go to start>settings control panel> click on system then click on device manager. Make sure that everything is working properly then in control panel click sound. if that is all working. Make sure you have the speakers connected in the right spot. You may also want to try the speakers on another computer to isolate exactly what the problem is.
Thank you,
lee
Nov 10, 2009 | Altec Lansing BX1020 Computer Speakers
Good Luck
Nov 20, 2008 | Altec Lansing AVS 300 Computer Speakers
53 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Sharps s
Ekse
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
