Question about Radio Communications
I think you will find the problem is in one of the microphone wires. The switch for TX/RX is in the mic, and if the RX wire opens up, you will not get any receive audio.
Posted on Jun 04, 2019
SOURCE: rci 2950 no audio period rx or tx
Check TR38 I have seen caps in the circut
go bad more then once if you have a schematic you should be able to find it if one
is bad,a capasator meter would help but you
can check them with a ohm meter.
Good luck.
Posted on Sep 16, 2009
SOURCE: RCI 2970
broken coax inside the radio going to the amp.. is the display ok? sometimes static from storms will knock out the processor and the radios will quit. have to replace the cb shop temple, tx on yahoo search processor board. to restore operation on that problem. is there more info can help us with?
Posted on Dec 08, 2009
SOURCE: Ihave a gargeled recive sound
Check the position of the mode selector switch. You may be receiving a SSB (single side band) transmission that is not on the exact same frequency as you or, your radio is in AM or FM mode. You will need to select either USB or LSB (upper or lower side band) and vary the clarifier knob until the sound becomes intelligible. If the sound does not become clear, try the other side band and repeat varying the clarifier knob.
Conversely, if you are in USB or LSB mode and there is a transmission on AM or FM, it will have the same garbled sound. Try changing the mode to AM and the FM. If it does not become clear, it is likely a SSB transmission and you are not on the exact same frequency of the transmission you are hearing. Vary the clarifier knob until it becomes clear - or change to the other side band if needed and try the clairfier again.
The short story is that you must be in the same mode and on the same exact frequency. When in AM or FM, this is less of a problem as these are much more wide banded signals than SSB signals.
The 2990 is really a 50 watt 10 meter amateur radio - but is geared to CBer's as it is easily modified to work in the CB frequency range and the so called "free band" between USA's CB (11 meters) and worldwide amateur 10 meter bands. Be careful transmitting this radio on CB frequencies as it violates FCC rules for power output there - and transmitting in the 28MHz - 29.7MHz requires a valid amateur radio license. Fifty watts on ham frequencies is tiny compared to the 1500 watts permitted. Why not get your ham license (here's how) and leave the "Chicken Band" (and all it entails) behind. You won't miss it!
I hope this helps and good luck!
Posted on Apr 13, 2012
SOURCE: I need a manual to base station CB Ranger RCI-2990
you can download a free manual on cb tricks
Posted on Aug 19, 2012
SOURCE: my rci ranger wont transmit but it receives great what is the problem
it could be several things......the rf final,bad mic,cold solder joint on the circuit board just to name a few.my suggestion is to find a good local cb shop,if no local shop find one along the interstate hwy most of the time they are located around or near some of the larger truck stops. tell the tech there what the problem is and go from there. good luck !!
Posted on Apr 06, 2013
Jul 03, 2015 | Radio Communications
Apr 19, 2014 | Ranger Radio Communications
Apr 04, 2013 | Ranger Communications RCI-6900F-25 CB...
Oct 15, 2012 | Astatic Road Devil RD104E CB Radio
Apr 24, 2012 | Radio Communications
Apr 18, 2012 | Radio Communications
Nov 07, 2010 | Ranger Communications RCI-6900F-25 CB...
Sep 24, 2009 | Radio Communications
Mar 11, 2009 | Connex 3300 240-Channels Base CB Radio
176 people viewed this question
