Question about JVC Televison & Video
How to clear producation mode in jvc av 70bt - JVC Televison & Video
Posted by shiva shiva on
Audio not ok pic ok
Hi ,
Check problem is in AV mode only or both AV and RF
If both mode problem is there follow the bellow
Other wise problem May RCA cable (AV cable)
I f you are able to open TV check speaker using a Multimeter (Tv should be OFF) continuity mode,is it shows 2 ohms or below speaker is ok, problem may be audio section of your TV.
Thank you
Apr 22, 2014 | JVC AV-21meu 21" TV
JVC AV21AT NO SOUND PIC OK
Hi ,
Thank you
Apr 22, 2014 | JVC Televison & Video
My pioneer av receiver vsx1020 produces same sound in front and back speakers
Try changing surround modes. You might be in 5 channel stereo mode.
Mar 14, 2013 | Audio Players & Recorders
Must I add something to my set to get HD?
Sorry ur tv is an analog tv set u will not able to get HD on to an anolag tv set.Analog tv dosen't have the abilities to produced a high enough resolution to get a HDTV modes.U want HDTV modes,must have a LCD that have 1080i or 1080p or plama tv.
Jan 17, 2011 | JVC AV-32S575 32" TV
I have a JVC AV-32F703 tv just replaced the vertical IC tv comes on but immedeatly goes into shut down mode by what could the problem be? Retrace lines was on top of picture before it started going into...
Chances are you should have checked some components related to that IC,namely an electrolytic capacitor.They tend to leak or short.That IC burned for a reason.
Sep 25, 2010 | JVC AV-32F703 32" TV
JVC AV-27430 27"
Go into your settings of the TV menu or there will be a single button on the JVC remote marked "CC" for closed caption. Press it or in the menu turn off the "TEXT" mode. With the text mode on you are allowing the TV to display text information wich means usually a black rectangular box that appears on the screen with no text in it. Usually on the cc button just press it until it scrolls through turning off the CC or text modes.
May 24, 2008 | JVC AV-27430 27" TV
JVC MODEL NUMBER AV-20N31
http://www.bruzziforum.com/vbf/showthread.php?s=7acab0606b230f96d8ded2112db03bf4&t=34
Nov 15, 2007 | JVC AV-56WP74 56" Rear Projection...
Jvc tv
try this:
Click "Display" and "Picture Mode" simultaneously this worked on my jvc av-25lx14
if it didnt work or if you dont have those buttons then try this:
click on "Muting" and "Info(its the button that has the"i" symbol"
Good luck
Sila Awad
Aug 10, 2007 | JVC AV-27850 27" TV
Televison & Video Logo
26 people viewed this question
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
